Question about Vidikron MODEL 65 Lamp
Only half a picture
Before I replaced the bulb, half the screen showed a great picture and then the other half showed straight vertical lines. I had ignored the replace bulb for a long time as the picture was still good. I replaced the bulb (I do not know my service code), and the picture is still half in place and the vertical lines continue on the right half of the picture.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
"the vertical lines" is not correlated with the lamp
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Posted on Mar 21, 2014
  • Lampdeng.com
    Lampdeng.com Mar 21, 2014
    sorry,I was make a mistake:my skype is not lampdeng. my skype is : lampdeng@hotmail.com
What causes vertical lines in right half of the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 12, 2015 | LG 42LH20 42 in. HDTV LCD TV
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Samsung ln46b500p3f shows half screen
you sure got original t-con board for replace? part#37704-cog from ebay have. if no you try again . good luck!
Sep 01, 2012 | Samsung Televison & Video
Verical lines on half of the screen
I have the same prob. Please help my *** out here!
May 25, 2010 | Toshiba REGZA 52RV530U LCD TV
Plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
Nov 23, 2009 | Panasonic Televison & Video
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Vertical line down the center of screen
A WD62827 is a V30+ chassis and is a DLP format projection screen Tv, not a flat screen, am I missing something?? For the symptoms you're describing with a WD62827 remove and reseat the DVI cable between the chassis and optical engine. If removing and reseating the DVI cable does not resolve the issue you may need to replace the Optical Engine part # 938P019020
BTW the current software version for this unit is 7.04.1F if you have anything less you might think about updating the software also..
Hope this helps!
Bill
Nov 29, 2007 | Mitsubishi WD-62827 62" Television
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Vidikron MODEL 65 Lamp Logo
94 people viewed this question
Top Vidikron Office Equipment & Supplies Experts
Lampdeng.com
Lampdeng.com
Tom Chichester
Les Morrison
Les Morrison
Are you a Vidikron Office Equipment and Supply Expert? Answer questions, earn points and help others
