F2 errror code for hyundai airconditioning
Model is HSAG180C
Gas smell comes through when i turn on aircondition
It appears you have a fuel leak under the hood, or a fuel lines to the engine may be leaking. Have the vehicle inspected by a qualified Hyundai Service Technician.
Jun 27, 2011 | Hyundai Santa Fe Cars & Trucks
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
WHAT IS ERROR CODE SC 45-20
Precisise your machine model qand the errror code.
Nov 12, 2009 | Minolta Office Equipment & Supplies
Mi 1998 bmw 318i won't pass smog because errror p1511
if you have the right code info it would be the "air control solenoid"
Check your local parts store for this...it may be a dealer only item though.
Sep 14, 2009 | 1998 BMW 3 Series
I have a 2005 V6 Sonata. The airconditioning
Replace the drive belt and make sure the belt tension is 'taut'
Jun 09, 2009 | 2005 Hyundai Sonata
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
