Question about Lands Phones
Sputtering and back firing
Driving down road and started to backfirs and sputter like out of gas, but not. Spark plugs good too. could it be fuel injector
    New Friend:
Smell like rotton eggs????
catalytic converter---
Posted on Feb 16, 2014
  • 150 Answers
SOURCE: I have a '06 Kawasaki
varnish
Posted on Apr 18, 2008
  • 150 Answers
SOURCE: 1996 road king.
coil?
Posted on Apr 24, 2008
Mitchy123
  • 216 Answers
SOURCE: spark plug problems
Do a compression check and lets go from there. Bad rings CAN cause fouling
Posted on Nov 15, 2008
v2iper
  • 150 Answers
SOURCE: 1999 Fatboy backfiring & no spark
The guy with the same problem..Your leaving your enrichner (choke) out thats where the 2000rpm and soot comes from...Original fellow I think you may have an intake leak around your manifold or carb.
Posted on Jun 14, 2009
  • 116 Answers
SOURCE: cannot keep bike running after it is warmed up
kinda tough not knowing what your rideing wether its injected or not but it sounds more like coil connections or camsensor
Posted on Jan 05, 2010
Backfire, Black smoke from exhaust, spitting and sputtering
If you have not replaced plugs start there A bad map sensor will also cause black smoke and poor running
Feb 15, 2014 | Dodge Durango Cars & Trucks
99 dodge ram 1500 sputters and quits
i would check three parts , i have seen a weak ignition coil make this happen, change fuel filter and last possibly either fuel pump or fuel pump regulator
Jan 12, 2013 | Cars & Trucks
2003 H-D Sportster 883 XLH backfire and sputter problem
There are two things that can cause what you describe: Lack of fuel, and lack of spark.
The easy way to eliminate is put an extra spark plug in your pocket....Ride the bike until it quits, then pull one plug wire, plug in your spark plug and hold the base of it against the block, and crank the engine, while observing the plug.
If you have spark, fuel flow issue is likely, check all filters, and strainers (in tank too). You can pull the fuel line and open the fuel valve and observe flow, but be careful of spark and fire, happens EASILY.
If you do not have spark, investigate the ignition system, if electronic, you can be overheating, usually requiring component replacement.
Apr 22, 2012 | Harley Davidson XLH Sportster 883...
Hello, I have a 1992 Camaro RS 25th Anniversary ed. 3.1 V6. 118k miles. 700r4 Transmission. & My problem is.. I ran it low on gas, put gas in it.. ran like ****.. missing.. sputtering.. low power.....
CHECK FUEL pressure and take a fuel sample see if has water in it. since started problem rt after getting gas sounds lik you got some bad fuel
Jun 02, 2011 | 1992 Chevrolet Camaro
Sputtering when driving down the road back off throttle then bike seem's ok but when apply throtle start's back to sputtering
That sounds like it could be a fuel mixture problem and is too weak. It could even be wrong spark gaps on the plugs. Check the plug gaps first. should be 25thou.
Jan 16, 2011 | 2002 kawasaki VN 1500 Vulcan Classic
Engine backfires then sputters and dies
Sounds like your culprit is the fuel pump my friend
Mar 30, 2010 | 1993 Chevrolet Suburban
Sputters then dies
Most likely a lack of fuel, check the fuel filter first.
Aug 13, 2009 | 1988 Saab 900
1998 Pontiac Bonneville SE 3.8L Backfires/ Sputters
sounds like the ignition module is going bad.
Aug 04, 2009 | 1998 Pontiac Bonneville
My honda sputters out and dies after 8-10 miles
Could be Lots of things Causeing that Frist Could be a Cracked Spark plug and Be your Timing out on it also could be Vacume Leack EGR stuck open or Closed Bad Wires Emissions Control System not workin Right
Mar 07, 2009 | 1991 Honda Civic
Will start & drive but after driveing it will sputter & die ?
Check the small ground wire from the engine to the body chassis. Remove it from both ends wire brush were the lugs connect also wire brush the lugs. Install some vaseline on the connection points and tighten.
Mar 07, 2009 | 2000 Honda Accord
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
