Question about Bertazzoni X366GGVX Stainless Steel Gas Range
X304GGVX door hinge - Bertazzoni X366GGVX Stainless Steel Gas Range
How to change door opening to other side
Hi Eleanor,
Without a specific model number I can only give general information, but, Kenmore fridges are all about the same, so here we go. Take a close look at your unit. You should observe several small plugs inserted on the side of the doors that don't have the hinges currently mounted. These inserts cover threaded holes that are used to mount the hardware for the hinges. If your fridge has two doors one above the other. remove the top hinge hardware, lift the door up off of the bottom hinge pin. then remove the bottom hardware on the top door. Typically the mounting screws are either phillips head or 1/4" hex head machine screws. You should now see that there is now a threaded hole in the same position on that side as the plug in caps on the other side. remove the caps from the one side and insert them in their respective holes on the other side. the door hinges will attach to the now exposed holes on the side that the plugs were removed from. But not yet. First remove the top hinge hardware on the bottom door, lift the bottom door off of the bottom hinge, and then remove the bottom door hardware relocating the bottom hardware to the other side. Install the bottom door onto the hinge pin of the bottom door hinge. Close the door then install the top hinge on the bottom door. Next install the bottom hinge and hardware for the top door, set the top door on the installed hinge, close the door add install the top door top hinge and hardware next. Same with the door handles. All of this info applies to the doors and the fridge itself.
Jun 26, 2015 | Kenmore Refrigerators
How do get access to the top driverside door hinge
Here is the repair procedure straight from Ford manual, but it doesnt give any information about access problems, I will ask a coworker and see if he knows:
Removal and Installation
  1. NOTE: Front and rear door hinges can be removed and installed using this procedure.
    Support the front door (20124) or rear door (24630) for service using Rotunda Flexi-Work Table 156-00070 or equivalent.
  1. Mark the location of the front door upper hinge (22800) or lower door hinge on the front door or rear door and body.
  1. Remove the door hinge-to-body retaining bolts.
  1. Remove the door hinge-to-door retaining bolts. Remove front door upper hinge or lower door hinge.
  1. To install, position the front door upper hinge or lower door hinge to the front door or rear door and body. Install retaining bolts.
  1. Adjust the front door or rear door as outlined. Tighten hinge retaining screw and washer assemblies to 25-35 Nm (18-25 lb-ft) and remove the support.
Apr 19, 2011 | 1996 Mercury Grand Marquis
I have a 1995 dodge dakota. I need to replace driver side door. Need to know how to take door off properly. Need diagram or something. HELP.
Removal & Installation
  1. Matchmark the hinge-to-body and hinge-to-door locations. Support the door either on jackstands or have somebody hold it for you.
  2. Remove the lower hinge-to-door bolts.
  3. Remove the upper hinge-to-door bolts and lift the door off the hinges.
Details of a common door assembly-Dakota shown
Click to Enlarge
To install:
  1. If the hinges are being replaced, remove them from the door pillar.
  2. Install the door and hinges with the bolts finger-tight.
View of the door hinges-1994-96 Pick-ups
Oct 23, 2010 | 1995 Dodge Dakota
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
93 silverado 2500need free online mechanical diagram of doors
GM Full-Size Trucks 1988-1998 Repair Information Doors - REMOVAL & INSTALLATION
R/V Series
See Figures 1, 2 and 3
If the door being removed is to be reinstalled, matchmark the hinge position.
  1. If the door is to be replaced with a new one, remove the trim panels weathersheets and all molding.
Fig. 1: Door hinge-R/V Series
  1. If the door is to be replaced with a new one, remove the glass, locks and latches.
  2. If equipped with a wiring harness, remove the trim panel and disconnect the harness. Guide the wiring out of the door.
  3. Support the door and remove the hinge-to-body attaching bolts. Lift the door from the truck.
  4. Install the door.
  5. Perform the alignment procedures indicated below.
Fig. 2: Door hinge components-C/K Series
Fig. 3: Removing the hinge spring
C/K Series
  1. On trucks with power components in the door, disconnect the battery ground cable.
  2. On trucks with power components in the door, remove the cowl side vent cover.
  3. On trucks with power components in the door, disconnect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  4. Cover the door hinge spring with a heavy towel. Using tool J-36604 or its equivalent, insert the blades of the tool between the spring coils and turn the barrel nut to compress and hold the spring. Remove the spring using the tool.
  5. Remove the lower hinge pin retainer.
  6. Using a plastic or rubber mallet and locking pliers, remove the lower hinge pin.
  7. Install a bolt through the lower hinges to hold the door while removing the upper hinge pin.
  8. Remove the upper hinge pin retainer.
  9. Remove the upper hinge pin.
  10. Support the door and remove the bolt from the lower hinge.
To install:
  1. Position the door and install the bolt in the lower hinge.
  2. Install the upper hinge pin. with the pointed end up.
  3. Install a new upper hinge pin retainer.
  4. Remove the bolt from the lower hinges.
  5. Install the lower hinge pin with the pointed end down.
  6. Install a new lower hinge pin retainer.
  7. Using tool J-36604, install the hinge spring.
  8. On trucks with power components in the door, connect the wiring going to the door, under the dash panel. Feed the wiring through the door pillar.
  9. On trucks with power components in the door, install the cowl side vent cover.
  10. On trucks with power components in the door, connect the battery ground cable.
ADJUSTMENTSee Figure 4 The holes for the hinges are oversized to provide for latitude in alignment. Align the door hinges first, then the striker.
C/K series utilize hinges that are welded to the door and frame. No adjustment is possible except when replacement hinges have been installed.
Fig. 4: Door adjustment check points
  1. If a door is being installed, first mount the door and tighten the hinge bolts lightly.
If the door has not been removed, determine which hinge bolts must be loosed to effect alignment.
  1. Loosen the necessary bolts just enough to allow the door to be moved with a padded prybar.
  2. Move the door in small movements and check the fit after each movement.
Be sure that there is no binding or interference with adjacent panels.
  1. Repeat this procedure until the door is properly aligned.
R/V Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 5mm Door edge-to-rear pillar: 5mm Door edge-to-front pillar: 2mm
C/K Series:
Door edge-to-rocker panel: 6mm Door edge-to-roof panel: 6mm Door edge-to-rear pillar: 4mm Door edge-to-front pillar: 7mm Door front edge-to-fender: 5mm
  1. Tighten all the bolts to 26 ft. lbs. (35 Nm).
Shims may be either fabricated or purchased to install behind the hinges as an aid in alignment.
Hope this help, TY for using Fixya (remember comment and rated this). Good luck.
Apr 01, 2010 | 1994 Chevrolet Silverado 2500
Written instructions for changing door on fridge freezer KGV36V10GB. Diagram is confusing!
Open door, unscrew hinge, Pull door top door off first, then remove middle hinge, then second door, then third hinge. ( good to take pic before so you know what direction the hinges are facing.
When putting on, put bottom hinge on first, then door (tape it close and in place) then second hinge, the top door (tape in place, THen finally the top hinge. Once hinges are in place, remove tape.
Jan 18, 2010 | Audiovox Bosch 718 World Cellular Phone
Bottom door hinge replacement easiest way?
Hinge, Door Removal and Installation
  1. NOTE: A second person is required if the Flexi-Work Table 156-00070 is not available.
    Support the front door (20124) using Rotunda Flexi-Work Table 156-00070 or equivalent.
  1. Mark the location of the front door upper hinge (22800) and front door lower hinge on the front door and body.
  1. Remove the front door hinge-to-body retaining bolts.
  1. Remove the front door hinge-to-door retaining bolts and remove the front door upper hinge and front door lower hinge.
  1. To install, position the front door upper hinge and front door lower hinge to the front door and body. Install the retaining bolts. Tighten to 25-35 Nm (18-26 lb-ft).
  1. Adjust the front door and front door upper hinge and front door lower hinge as outlined, and remove the support.
Jul 01, 2009 | 1995 Ford Thunderbird
Thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Jan 18, 2009 | Thermador C301U Electric Single Oven
Bertazzoni X366GGVX Stainless Steel Gas Range Logo
Top Bertazzoni Kitchen Ranges Experts
Dan Webster
Dan Webster
Dan Connors
Dan Connors
 Gary Gemmell
Gary Gemmell
Are you a Bertazzoni Kitchen Range Expert? Answer questions, earn points and help others
