Question about Yard Machines 28" Two-Stage Snowthrower
Electric Maztang mt 968 auger wont run - Yard Machines 28" Two-Stage Snowthrower
    Master:
  • 755 Answers
The motor runs but the auger does not , if so the bolt snapped in half from hitting something that you should have not hit , this is a normal thing so as to not blow up the engine , it is a safety feature in all snow blowers , just get the right bolt or make one grind it down to where it will break easy but will work the auger , they sell them on ebay for a couple bucks but I make mine
Posted on Feb 03, 2015
MAZTANG MT-968 stopped after 30 seconds and won't start. What now?
Check your circuit breaker in your house could need resetting.
If you are plugged into a GFI outlet it may need resetting as well.
That happens a lot with GFI receptacles.
Jan 09, 2015 | Maztang Mt968 18 inch 13.5 Amps Electric...
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Ariens st350 snow blower wont blow snow, augers wont spin
there is a bolt that goes thru auger and spinning shaft (look for a hole where it once was) holds the augers to the spinning shafts, it is called a shear pin, it is a safety feature, and made of softer metal, so if you pick up something too hard with the auger, it wont lock up the engine, or break engine crank shaft.find an ariens repair shop to purchase the shear pin so you get the right softness of metal.
Mar 05, 2013 | Garden
Cecilware MT Mini granita machine
you have a magnetic auger drive which means it's sealed between the motor and the inner auger. if there is liquid actively dripping on the inside from the back, the plastic under the magnet on the back of the inner auger has worn through. remove the bowl, the outer auger, and the inner auger (pull hard- it's a big magnet). the tubular black plastic that the auger was around may have scratches and holes in it. press the plastic all around the outside. if it gives, you have a hole. unfortunately, in order to get that replaced you need to sever the refrigeration line, which means big bucks. sorry, but you've been had.
Apr 16, 2012 | Cecilware MT 2 UL FrigoGranita Slush...
Auger wont spin.
sounds like you broke the shear pins? They are bolts that run through the auger/shaft and should be gold in color. DO NOT replace them with anything but a shear pin that is made for your machine. Simply use a small punch to remove what is left in the hole and line up the shaft with the auger and install the new pin.....
Dec 26, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Ge side by side refrigerator model tfx20jrx ice wont dispense
If the auger will move freely with ice out of the pan then the auger motor may be defective. Sometimes the connection in the door switch is defective. When the door is closed the switch turns the circuit on to the auger and control panel. Because the auger uses more amps that the water dispenser the door switch may be the problem or auger motor is just worn out.
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Engine Dies When Auger Engaged
Bough Sno-Tek 24 in. Two-Stage Electric Start Gas Snow Blower - under 2 feet of snow and engine dies when Auger is enagaged! Hope someone can help.
Jan 28, 2009 | Garden
Yard Machines 28" Two-Stage Snowthrower Logo
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
