Question about Dryers
Whirlpool (Old) dryer makes a zapping noise at the outlet. It will run, but there is no heat
I heard the outlet (220) making the snapping-zapping noise when I started the dryer. One of the prongs is burnt looking. Dryer runs as if it's working, but there is no heat.
    Sergeant:
  • 239 Answers
Unplug the dryer, IMMEDIATELY.
Get a Pro to check for wiring shorts or heating elements that are, burned loose, touching or other wise going to ground...
What you are describing is a severe fire hazard if not corrected...
Posted on Feb 16, 2014
  • 2920 Answers
SOURCE: Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Posted on Feb 25, 2009
  • 1122 Answers
SOURCE: Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
Posted on May 08, 2009
jsrock516
  • 5911 Answers
SOURCE: my whirlpool dryer won't heat up and makes a lotof
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If the model number you have this listed under is correct, the part numbers are as follows:
Heating Element - 279838
TCO/Hi-Limit Thermostat Kit - 279816
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
All your heating circuits are accessible in the rear of the dryer by removing the back panel. Just remove the screws around the perimeter of the back panel and the heating circuits will be located on the right-hand side. Refer to the exploded view diagrams at the websites I mentioned for reference. The heating circuitry is located under the "Bulkhead Parts" section.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
Posted on Oct 31, 2009
erpaalai
  • 999 Answers
SOURCE: Dryer is making a rattling noise.
Rattling could be anything from a bad idler or support pulley or coins in the vanes. If you can hear it you can find it pretty easily.
Eric
Posted on Jun 13, 2010
My whirlpool dryer wont start, I replaced the start switch and the door switch seems fine. I hear a ticking noise
The door switch may not be making contact. All dryers also have a High Limit thermostat that shuts down the dryer when too hot. The high limit thermostat should reset when the dryer is cooled off but may be defective. If the dryer is electric, 110 volts run the drum motor, and the other leg of the 220 line is for the heating element.
May 05, 2014 | Whirlpool Dryers
WHIRLPOOL DRYER WONT HEAT
1st thing is to reset the house breaker for the dryer, it is a 220 volt breaker, the dryer only needs 110 volts to run but needs 220 to heat, so the breaker can be partially tripped which will only allow for it to run but not heat. If that is good make sure where the cord attaches to dryer terminal block isn't burnt up, you can lose 220 there as well. If you have 220 to the dryer then you either have a bad element or thermal cutout located on the element with the hi limit thermostat, those parts can be tested for continuity out of operating condition
Jan 31, 2014 | Whirlpool Dryers
My Whirlpool Cabrio just started making a clicking noise. It's only a year old. Any ideas?
is it a noise like nails on a chalk board if so your heating element could be hitting the back side of your dryer and making a clicking noise or scratching sound does it heat and dry the same
Jun 27, 2011 | Whirlpool WED9200SQ Electric Dryer
Dryer is not drying.
could be something as simple as thermal fuse or heater element.  did you check to make sure you have 220 v at the outlet..
Jul 28, 2010 | Whirlpool LER5636P Electric Dryer
Motor runs but dryer does not get hot
bad heat element or thermostat. but first check to make sure u get 220 volts to the dryer. if not 220 volts, then check your breaker, could be half-tripped.
Oct 31, 2009 | Whirlpool LER8648P Electric Dryer
MY drier heating element shows 9 ohms continuity, it also shows 120 volts into and out of it when the drier is running. But the heating element wont heat up?
Have you checked the voltage at the outlet? You're supposed to read 220-240 VAC at the heating element. Your dryer heating circuits require at least 220 VAC to work. The motor, however, only uses 120 VAC. That's why your dryer may be running, but the heating circuits aren't heating. I would go back and check your outlet. You may be missing one leg of the 220 service, or have a loose, burned, or broken wire in the plug or terminal block (on the back of the dryer). Let me know what you find. I hope this helps you.
Oct 17, 2008 | Whirlpool Dryers
Will not heat
You need to make sure that you are getting 220 volts into the machine. First check and make sure that your outlet has 220. Then after you have done that make sure that you have 220v going to the dryer. If after you have done this also make sure that all of your wires are on, on the parts that you have changed
Jul 14, 2008 | Maytag Neptune MDE4000 Electric Dryer
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
How do you replace the heating element
first you need to make sure the heating element is the problem dryers will run on 110 but will not heat with out 220 first you need to confirm that you have 220 then let me know what you find hold my rating till we are done and don't buy a heating element yet
Jan 25, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer
    You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
