Question about Lowrance LCX-25c GPS Receiver
Gps not responding comes up on screen
Turning unit off does not help but pulling fuse from power to antenna resets it but intermittently.
5 Suggested Answers
SOURCE: lowrance332
had same problem with lms337. i had upgraded the unit but had not upgraded the lms2000 gps module. i was turning the isolator on in the boat which powers up gps module, if the lms337 is not powered up as well the gps unit goes to sleep. the upgrade fixes it by checking that the unit has not been turned on periodically. otherwise as soon as you power up gps module also turn on lms337. lowrance product support sorted this for me.
Posted on May 08, 2008
  • 111 Answers
SOURCE: I have a lcx16 sounder gps with a lgc12s antenna
more than likely you do or you have a bad connection. It's always best to take this sort of issue to a shop in the event something is wrong with the unit itself before buying the new gps.
Posted on Jan 25, 2010
SOURCE: lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Posted on Jan 12, 2011
jackwollman
SOURCE: I have a h20C plus
will not lock on position or on 2d or 3d or wass
Posted on Sep 25, 2011
When I turn my Garmin Nuvi 680 on, and the first screen appears about not driving while operating the Garmin, I have to hit "agree" button several times before it goes to main menu, and from that...
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Sep 21, 2011 | Garmin Nuvi 680 GPS Receiver
My garmin 200 gps is not coming on?
Try performing a soft reset on the unit.
Resetting Your nüvi
If your unit stops responding, turn off the unit, and then turn it back on. If this does not help, perform a reset using the reset button on the bottom of the unit.
Caution: Do not reset your nüvi with a ballpoint pen or other sharp object, which can damage your unit.
1. Disconnect the nüvi from external power.
2. Press the Reset button on the bottom of the nüvi.
3. Connect the nüvi to a power source.
A hard reset can also be done but will erase all the user data.
This is done by with the unit off and pressing and holding the bottom right hand corner of the screen while turning the unit on.
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
Sep 15, 2011 | Garmin nuvi 200W GPS Receiver
Garmin turns off when Garmin screen comes on
Resetting Your nüvi
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance332
Mar 02, 2008 | Lowrance LMS-332C GPS Receiver
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
Touch screen failed after I added external antenna
have you tried resetting it (press and hold find, the press power)
Dec 04, 2007 | Garmin StreetPilot 2720 GPS Receiver
Lowrance LCX-25c GPS Receiver Logo
54 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
