Question about Geovision GV-650 BNC (GV6504) Video Capture
GV650 installed but I cannot see configeration menu
Cameras display too large. Cannot see rest of screen. Need to reduce
  • 1,087 Answers
Try un-installing the software, then re-boot and reinstalling the software again and full install it and then restart your PC
Posted on Feb 16, 2014
How do i reduce the text and icons on my laptop display/screen
Assuming you have a Windows system:
  1. First make sure you don't have the type size and icons set to a large size. Right click on your Desktop and choose 'Personalize'. Then in the lower left choose 'Display'. Make sure that you have selected 100% as the size of text and icons. If you have, proceed to #2
  2. Make sure that you are displaying at the native resolution on your laptop. If Windows doesn't have the right software drivers (instructions) for the display it will use some generic drivers which will work but will make everything appear large and potentially slightly fuzzy. Verify the potential resolution of your laptop with HP by looking up the model on their website and then checking the screen resolution. Then right click on your Desktop and pick 'Screen Resolution' from the context menu. Verify that the resolution is the same as the HP's listed resolution. If not, change it to match. If you can't change it to match that means you don't have the correct video card driver installed on your notebook. Go to #3
  3. To install the correct video driver for your notebook, go to the HP Support site and click on 'Detect my product'. This will install some HP software that will recognize your system and load the appropriate updated software drivers for all components. You want to specifically find 'video drivers' but it will probably be OK to let others found by the website be installed. Install the video drivers and then if the screen isn't displaying at the correct manufacturer resolution, go back and repeat the instructions in step 2 to manually set it.
That should get everything displaying at the correct size.
Drivers Downloads
Feb 18, 2015 | HP Pavilion Computers & Internet
From the time i hit button and the time the picture actually takes is way to long i miss the pic how can i fix this
This "shutter lag" is a common situation with most compact point&shoot cameras. The camera has to do a lot of work when you press the button, including acquiring focus, metering the exposure, and switching the circuitry from displaying on the screen to recording to memory. More sophisticated (and more expensive) cameras have more hardware to reduce this lag.
You can reduce the shutter lag by anticipating the action. Press the shutter release button halfway to focus and meter. Keep it pressed halfway until the right moment and then press it the rest of the way.
Jun 25, 2012 | Kodak EasyShare C330 Digital Camera
All pictures seems like to be over exposed
If this is showing up after printing the photos you need to change the exposure settings on your camera. You may have inadvertently changed the default setting so try restoring them first. If, however, it is the appearance of your phoros on the camera lcd screen that looks overexposed reduce the brightness of your display. Some cameras have a control on the bottom for doing this while others need you to go through the menu.
May 23, 2011 | Cameras
Using as a duo monitor. when transfering screen image to it, the screen is extremely too large . How do I reduce the size?
Increase the resolution of the monitor with the really large image. Also, in vista and windows 7, go to display and there should be a button to reduce the size of whats on the screen.
Feb 02, 2010 | Samsung Computers & Internet
My phone is deleting my text messsages and my calls I have made. When I go to check if my message sent, it says there is nothing in my inbox or outbox. How does my phone delete my stuff without me doing...
Cause 1 A number of large applications are installed on the BlackBerry smartphone. Resolution To resolve this issue, complete the following steps: Make sure that the BlackBerry® Device Software is installed on the computer to display the correct total application space. Determine the application space that is available on the BlackBerry smartphone by completing the following steps: Connect the BlackBerry smartphone to the computer. Open the BlackBerry® Desktop Manager. Double-click Application Loader. At the Device Application Selection screen, under the application selection window, note the total application space. Note: Select the List additional applications that are installed on the connected device check box to include the applications that are installed outside of the BlackBerry Device Software applications and the file sizes. Remove applications that are not required. For example, remove additional language packs and themes. Cause 2 A large amount of BlackBerry smartphone user data is present on the BlackBerry smartphone that cannot be removed by the Low Memory Manager. Resolution To resolve this issue, complete the following steps: On the BlackBerry smartphone, click Options > Status. Display the menu, and select Database Sizes. Reduce the number of items that are increasing the size of the database. For example, if the Address Book database is large, remove out-of-date contacts. If the Content Store database is large, move media files from the BlackBerry smartphone memory to a media card. Cause 3 Media settings may contribute to low memory capacity. Resolution Modify the Device Memory Limit settings by completing the following steps: On the BlackBerry smartphone, click Media. Select a media application. Display the menu, and click Options. Set the Device Memory Limit to the lowest setting field. Display the menu, and click Save. Note: Some BlackBerry smartphones have integrated cameras without a media card. As a result, some features have been added to handle picture storage on the BlackBerry smartphone, including the following: · Reserved Pictures Memory: In BlackBerry Device Software 4.2.0, the default value setting is 10 MB. In BlackBerry Device Software 4.2.1 - 4.7, the default value setting has been reduced to 2 MB. This setting reserves memory for pictures that the BlackBerry smartphone might take, and reduce the File Free amount that is displayed in the BlackBerry smartphone. This makes sure that the BlackBerry smartphone has memory available for pictures that are taken when a media card is not inserted in the BlackBerry smartphone. · Device Memory Limit: The default value setting is 20 MB. This prevents the BlackBerry smartphone from storing more than the specified amount of memory use. Cause 4 An application has expanded beyond intended memory boundaries. Resolution Note: In the Java® operating environment, applications increase and reduce memory usage when the applications launch, run required processes, and close processes. An application may use more memory than it is intended to use. Please make note of the values outlined in the following steps: On the Home screen of the BlackBerry smartphone, click Options. Click Status and note the values listed for File Free and File Total. Divide each of these two values by 1024, so that they are measured in kilobytes (KB). Record the new values, and name them as Displayed File Free and Displayed File Total. Display the menu, and click Database Sizes. Record the value shown in the Total Size field at the top of the screen. Open BlackBerry Desktop Manager, then open the application loader tool. Click Next on the Welcome screen. Connect the BlackBerry smartphone to the computer and allow the application loader tool to detect it. You might be prompted to type a password. Click Next on the Device Application Selection screen. Verify that the List additional applications that are installed on the connected device check box is selected. Record the value for the Total application space, located at the bottom of the window. Calculate the Reserved Pictures Memory for BlackBerry smartphones that have integrated cameras. If a camera is not integrated, proceed to step 12. On the BlackBerry smartphone, open the Media application. Display the menu, and click Options. Note the Reserved Pictures Memory value and multiply that value by 1024. Record the value. For example, 2 MB * 1024 = 2048. To calculate the Total Amount of Memory In Usage, add the values for Total Application Space, Total Size, and Reserved Pictures Memory (if applicable). To get the Calculated File Free value, subtract the value for Total Amount of Memory In Usage from the Total Flash Memory supported by the BlackBerry smartphone.
Oct 29, 2009 | AT&T Blackberry Curve 8300 Smartphone
Camera pictures are jumping arroung on the geovision screen.
try calling up the system on the 16 screen to see id if thy still jump around if not and its only on the single screen then u have the camera rotation on wich u can turn off. its at the bottom on the right it looks like a monitor with arrows pointing to the right
Dec 17, 2008 | Geovision GV650-8 GV-650-8 GV 650-8 60FPS...
Fonts and brightness
1.Change your display settings.
Right click somewhere on your desktop, then click on properties.
Click on the apperance tab.
Under Font Size:
change it to large, or even extra large.
2.
Use the buttons on your monitor. Usually there is a menu button. Navigate your way through the menu to find a brightness options.
3.
Just head over to the manufacturers website for that info.
If its a dell, go to www.dell.com
if its a gateway, go to www.gateway.com
Go to their support section of their site, and just look around.
Hope this info is useful.
-Chad
Dec 11, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Taking a smaller image from S80
In picture-taking mode, hit the Func Set button. You will see menus of options along the left side and bottom of the display. Tap the bottom of the scroll ring (the ring around the Func Set button) until the bottom option of the left menu is highlighted in red. This option sets the image size of the pictures you are taking. Change this size by rotating the scroll wheel. The 5 options are Large, Medium1, Medium2, Medium3, and Small. The image size in pixels is displayed above the bottom menu as you switch between sizes. When finished, hit Func Set again.
Jun 25, 2007 | Canon PowerShot S80 Digital Camera
Sending photos as an e-mail attachment
When sending photos as e-mail attachments, the image (file) size should not be too large. Use the included image viewing program called Image Expert to save photos in reduced size. For instructions on installing Image Expert, see "Installing the image viewing program" on page 42 of the Instruction Manual. 1. Launch Image Expert. 2. Choose "Open Image" from the "File" menu. 3. Specify the image you want to reduce, then click "Open". If the camera is connected using the USB cable, it is displayed as a removable disc. images on the camera can be opened directly by specifying the remove-able disc. 4. Click on "Change Size" in the "Image" menu. 5. Input values at "Width" and "Height", then click "OK". If "Keep Aspect Ratio" is checked, the size is changed without changing the image’s vertical:horizontal ratio. 6. The image is displayed at its new size. 7. Click on "Save As" in the "File" menu to save the image with the new size.
Sep 11, 2005 | Toshiba Sora PDR-T10 Digital Camera
Geovision GV-650 BNC (GV6504) Video Capture Logo
56 people viewed this question
Top Geovision Televison & Video Experts
Rommel Balcita
Mark Magill
Mark Magill
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
