Question about Barenthal Home
Non-Stick Coating peeling off
Used my 18.5 x 13 roasting pan last night. while cleaning with Polmolive liquid dish detergent & scotch Brite scrub sponge noticed that the coating on the bottom of the pan was peeling off in lrg sections Now What !!
jerryg50
  • 1667 Answers
SOURCE: Non-stick peeling off
You should get in touch with the manufacture service rep, or directly in touch with them to find out how to order spare parts.
I found that with Tephlon coatings, after some time they all start to peel and not perform very well.
Jerry G.
Posted on Jun 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing.
Posted on Aug 12, 2008
SOURCE: Bread Machine non-stick starting to peel off
The peeling is not your fault. I have had the V20 version for 4 years. I got the company to replace my pan (the first time) when it started to peel after just over 1 year. I would contact their customer service dept. (1-800-733-6270) and request a new one. If you have to purchase it, the pan will cost you $55 + s/h. After almost 2 years, my replacement pan is starting to peel as well. The kneading blades have to be replaced every 1-2 years (according to their own customer service rep) at a cost of $12 + s/h. My first set lasted about 2 years; the second set only about 13 months. I only use my machine once per week. You can find the replacement parts at http://www.zojirushi.com/user/scripts/user/model.php?product_category_id=13 I haven't found a great way to clean them. I'm so paranoid about scratching them or getting them started peeling that mine usually don't end up being as clean as they probably should be! Good luck getting a free replacement pan.
Posted on May 12, 2009
F1xer
  • 415 Answers
SOURCE: using a Farberware 12 pan coating comming off
non stick coating are volatile and have a short life span depending on the frequency of cooking and washing which wears it out if you are a keen amateur cook/chef my advice is go for HARD ANODISED which is russian space technology in your kitchen or classic copper pots/pans but they are costly,
to help preserve your non stick 1. do not wash straight after let it cool down, 2. always use plastic or wood utensils.3. be gentle,
hope it helps.
Posted on Jul 29, 2010
  • 15639 Answers
SOURCE: breville toaster oven non stick pizza pan coating coming off
f you want to have a non stick coating you will have to order a new pan. There is no way to get a coating like that to stick again or even repair it. You might also want to scrape it off and go back to the old school method of greasing the pan.
Posted on Aug 10, 2012
They are peeling inside. Only had 3 years. What do I do?
bakers use black steel trays in which to bake bread
they are only covered in butter to stop sticking so if you follow the same procedure it will be alright
the covering that is coming off is probably the non-stick teflon coating which medical evidence proves not to be good for us as it breaks down with heat and age and is basic carcinogenic in nature
Look at all your old non stick pans and ask yourself , where did all the covering go?
Dec 15, 2015 | Kitchen Appliances - Others
Peeling nonstick coating
It can't be fixed. In the future, use only plastic cooking utensils so they won't scratch off the non stick coating. You can line the pan with foil if it is a baking pan, if it's a frying pan, there's no fixing it.
Apr 07, 2014 | KitchenAid 16-Inch by 13.5-Inch Roaster...
How to clean sticky ceramic fry pan
DO YOU MEAN A CAST IRON PAN OR NON STICK? If it is not stick you have to use a chemical that will remove glue from any object and then rinse well. Do not scrap. Let soak in for about 15min. and then scrub with a kitchen dish scrubber. This may help.
Mar 22, 2013 | Home
I had macaroni stick in one of my pots, how do I get it clean. It's blk inside the pot,
To remove stuck on food use water (the world's strongest universal solvent). But add a degreaser. Degreasers change the surface tension of water molecules to make the water droplets much smaller. Once they are smaller they can get into areas to start dissolving what it could not approach previously. Detergent being a surfactant also allows mixing oils and water. Hot soapy water works better. We used to use boiling water in a chinese restaurant i used to work at. Boiling water helps alot. Since your food is charred it is more likely carbon sticking to the non-stick surface. Your non-stick surface must not be non-stick anymore due to using the wrong chemicals or pads on it. High temperatures make silicone type non-stick coatings fail too. If there is no more non-stick coating to worry about you could use an oven cleaner. Oven cleaners are made of caustic soda or lye. Lye is made from common table salt (sodium chloride) Oven cleaner is great at attacking carbon but not very friendly to aluminums or the finished paint on any metals on appliances. Use your own discretion.
Mar 21, 2013 | Cook's Essentials CooksEssentials 3 Quart...
Using a Farberware 12 pan coating comming off
hope it helps.
Jul 29, 2010 | Faberware Kitchen Appliances - Others
Since your machine is only about 6 months old, it should still be covered under warranty. I'd contact the manufacturer. (Contact information should be in the instruction manual). The teflon coating is just a sprayed on coating. Once it starts to peel, it's not safe to use them. It becomes hazardous (possibly eating it in the bread).
It sounds like you've taken care of the pan as it's supposed to be. If this was an older machine, I'd suggest ordering a new pan. You can find them on the internet quite easily.
Apr 01, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Egg poacher tray
Pans, if they are in stock, can be ordered, but they will peel just like the first one. I refuse to pay $5 plus shipping for a faulty product. If the pan is that replaceable, it should be available retail in the stores. I finally just scrubbed what I could of the peeling coating off and (surprise!!!) the pan does not stick any more than it did with the coating. It doesn't look as nice, but save your money - just keep using the pan. I love the toaster, but the company has a great money maker in this faulty item and that dissapoints me that they settle for such mediocrity. At minimum, the company could make the pans more readily available for those who are concerned about the aethetic appearance of the poacher pan or develop a nice looking pan without the apparently useless coating. I use a nonstick spray and the egg comes right out.
Nov 15, 2008 | Back to Basics TEM-500 Egg & Muffin...
NEED EGG POACHER TRAY
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4155&secid=53&linkon=category&linkid=98
$5.00 plus shipping or somewhere around $10. How much is a new toaster? I just scrubbed the remaining coating off my replacement pan that also peeled and it works fine. $10 is too much money for something that will peel just like the original. Too bad they won't make them available in stores that sell the toasters and at least save the consumer shipping.
Apr 12, 2008 | Back to Basics TEM-500 Egg & Muffin...
Home Logo
474 people viewed this question
Top Barenthal Home Experts
Donni Steen
Tom Chichester
Are you a Barenthal Home Expert? Answer questions, earn points and help others
