Question about Canon Office Equipment & Supplies
HOW TO RESET ERROR E100 IN CANON NP7160 ERROR
  • 168 Answers
SOURCE: canon ir210s gatting error E100
that is a defective laser error code sorry
Posted on Dec 23, 2008
  • 489 Answers
SOURCE: Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
Posted on May 28, 2009
  • 1126 Answers
SOURCE: canon ir5070 i have an error code e100-00001 what does this mean
E100 code
Laser Shutter not opening
Possible mechanical failure or cracked/damaged Primary Fan Duct preventing the Laser Shutter from opening fully.
Posted on Jun 03, 2009
canontech
  • 1219 Answers
SOURCE: Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
Posted on Mar 02, 2010
SOURCE: canon-lbp2900-error-code-e100-0000.
J AI UN IMPREMANTE CANON 2900APRES L INSTALATION ELLE S AFFICHE UN CODE E1000000 J AI FAIT BEAUCOUP D ESSAY POUR ARRIVER A RESODRE SE PROBLEME MAIS J AI PAS ARRIVE JE DEMANDE AIDE ET MERCE BEAUCOUP
Posted on Apr 12, 2011
Model mf4412 printer. What does error code E100-0001 indicate?
Well im having the same issue E100 error on my xbox one as it was never update till the other day i was thinking is it possible if the nand dumpable and get the keys or signature from it and replace it with a working nand i know it still works cos i able to do the recovery mode with the offline update dianogtic from microsoft but still error E100 after reset
for more help visit CBR Tech Solutions
Jul 16, 2015 | Canon Office Equipment & Supplies
Error E100 on Canon iR1024A
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Jan 31, 2013 | Office Equipment & Supplies
Mf4410 error code e100-0001
Code error e100-0001 canon 4430
Was This Helpful?
Sep 17, 2012 | Canon I-Sensys Mf4410 All-In-One Laser...
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Dec 14, 2011 | Canon Office Equipment & Supplies
Canon copier np7160 occured E000 error, How to
The heater that melts the toner into the paper has a fault. This is an error that needs a copier technician. Good luck.
Dec 14, 2009 | Canon Office Equipment & Supplies
Canon ir5070 i have an error code e100-00001 what does this mean
E100 code
May 16, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Mar 26, 2009 | Canon Office Equipment & Supplies
Error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
I have an error code on my printer Error Code: E100 0000 E100 0001 it is a canon LBP5000
For more help visit cbr tech solutions
Sep 04, 2008 | Canon Office Equipment & Supplies
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
27 people viewed this question
old marine
old marine
