Question about Holmes Products Humidifiers
How many feet does HM3855L Model cover?
What model of Humidifier covers the most area?
2 Suggested Answers
  • 3 Answers
SOURCE: I need the rubber o-ring on the water fill cover
Please call the Venta Customer service team.
1-888-333-8218
If you have proof of purchase the part ( cap) is covered under warranty. If you do not it will cost $13
Posted on Feb 27, 2009
I need top cover for my humidifier part number 324866-301 does anyone know where I can find one?
Shop for Humidifiers' top cover on Google
CPAP.com - H4i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../resmed-h4i-heated-humidifier-top-cover-seal.html
People Who Bought H4i™ Heated Humidifier Top Cover Lid and Seal Also Bought. ... This is the plastic cover used with the Resmed Humidiare H4i Heated Humidifier. ... People Who Viewed H4i™ Heated Humidifier Top Cover Lid and Seal Also Viewed.
HumidAire 3i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../H3i-Heated-Humidifier-Top-Cover-and-Seal.html
This is the plastic cover used with the Resmed H3i Heated Humidifier. It also includes the plastic gasket below the tube connector.
Sep 29, 2015 | Humidifiers
What to Look For when buying room humidifier?
When going to buy a humidifier always check these points:
Technology used: Ultrasonic is good and inexpensive
Performance: The area it covers
Features: Does it offer both cool mist or hot mist
Design: compact and sleek design
customer support: The process of servicing and maintenance etc.
Read these top humidifier reviews to get the best
GroomNStyle Top 5 Best Humidifiers 2015
Jul 31, 2015 | Humidifiers
Looking for manual HM1865
This link should open the manual for you. I covers both the frog (the model you have) as well as many others. http://cache.air-n-water.com/manuals/crane-ee-3191.pdf
Mar 03, 2014 | Crane Frog EE-3191 1 Gallon Humidifier
I can't get the pad out to change. How do I do that?
if this is the bypass model there is a screw at the bottom of the cover that needs to be loosened. then the cover will flip up to expose the tray that holds the pad. take the tray out and squeeze the tabs on the black filler port to remove it. once the tray is out the top distribution tray can be removed by pulling the lower part off the tabs on the distribution tray. once they are apart remove old pad and wash both parts very well. You may need to scrub off the calcium build up or soak it in CLR to loosen scale. Once you have done this put the new pad in and clip the black filler port back on and test the humidifier.
Oct 31, 2013 | Honeywell HE265 Humidifier
Model 760 Aprilaire makes a loud noise when running. It almost sounds like the blade is hitting something. Its 10 years old !! I built the house so if you can tell me for sure what it is I'm sure I can fix...
I think you're on the rate track. If it's ten years old the blade and.or the shaft may be worn out. Turn off the water line feeding the humidifier.Turn off the electricity to the unit. Drain the tank, open he tank cover and try spinning the blades with your hand. That way you can tell and see what its rubbing against and if it can be repaired. But, if it's 10 years old, parts may not still be available for that specific model.
Good luck. Hope that helps.
Feb 11, 2011 | Aprilaire 700 Humidifier
How do I remove the thermostat cover to change the battery?
Many of the newer Honeywell models have a battery compartment that can be accessed without removing the thermostat.
Look for a small tab at one of the top corners of the thermostat. If this is not the case try pulling directly away from the wall at the bottom, then tilt up.
Aug 27, 2010 | Honeywell Power Humidifier: Furnace...
I need the rubber o-ring on the water fill cover for my Senbeam humidifier model 696 please help get this part. my phone # 320 269 9368
1-888-333-8218
Feb 27, 2009 | Sunbeam Ultrasonic 81696 Humidifier
I have a Honeywell HE360A Humidifier and everything is installed now I am trying to wire it. The wiring diagram is very vague. Does anyone know how to correctly wire this? I have the humidifier, a...
Peice of cake: You run the white to sail switch the to common 2. Yrun thr re to humistat switch then to the white on the control board or conact us www.airenergyexperts.net
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Water seeping through drain spud area of Aprilaire 600 model.
Clean it and dry it thoughly. Apply a small amount of 100 % silcone caulking with you finger. Seal it on both sides. Allow it to dry thoughly before it gets wet or it will leak.
Jan 22, 2009 | Aprilaire 600 Humidifier
Filter
If you email me at jennju@hotmail.com, I can send you a pdf of the manual for this product. I had the same model and was able to remove the fan cover by slightly twisting it and pulling up -- was able to clean the unit very well once I removed the cover! good luck...
Dec 03, 2007 | Honeywell DH835 Humidifier
Humidifiers Logo
24 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
Ben Eng
Level 1 Expert
Tom Chichester
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
