Programming guest room remote using hotelmaster LodgeNet lrc-3210-p
Which buttons on master remote do i press to transfer the program to guest room remotes (this is done thru infrared)
4 Suggested Answers
SpideRaY
  • 687 Answers
SOURCE: how to program HRS URC-383 remote
Goto www.diplodocs.com they have a few in there but not this one at the moment just register your e-mail and they will let you know when someone uploads it.
I will do this as soon as I find it for you.
Posted on Oct 10, 2009
SOURCE: Programming Remote
turn your tv on then hold the tv button down until all the little buttons on top begin to blink one at a time. it's about a 10 count. then the tv light will remain on while the light is on put in the code and the light will blink after the code is entered. if it is the right code your tv will turn off.
Posted on Sep 25, 2007
  • 5 Answers
SOURCE: I m trying to program my RC64 remote for Direct TV
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Posted on Jan 10, 2010
Testimonial: "Thank you thank you thank you!!!!!"
I have the LRC-3210 remote and need to program it, the old style would have them eye to eye and press three buttons .from what im seeing theres supposed to be a code? ok so where do i find the code?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Nov 16, 2015 | Televison & Video
How do i program a jumbo universal remote to my seiki tv
you cant,
Follow these steps to program a device into your remote control. There are two ways to program your remote. If you already know the code for your device, you can program it into your remote manually. If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Programing codes for the remote. If you do not see your device listed, you can use the code search feature to program the device into the remote.
TV Codes
TV Code List
ACME ADA ADC ADMIRAL ADVENTURA AIKO AIWA AKAI ALLERON AMARK AMTRON AMSTRAD ANANATIONAL AOC APEX ARCHER AUDIOVOX BANG&OLUFSEN BELCOR BELL&HOWELL BRADFORD BROKSONIC BROKWOOD CANDLE CENTURION CAPEHAPT CENLEBRITY CENTURION CETRONIC CHANGHONG CITIZEN CLQIRTONE CLASSIC COLORTYME CONCERTO CONCIEREG CONTEC/CONY CRAIG CROWN CXC DAEWOO DAYTRON DIMENSIA DUMONT DYNASTY ELEKTRA ELECTROBAND ELECTROHOME EMERSON ENVISION FISHER FUJITSU FUNAI FUTURETEC GE GIBRALTER GRUNDY HALLMARK HARVARD HITACHI HAIER IMA INFINITY INTEQ JANEIL JCB JC PENNY JENSEN JVC KAWASHO KAYPANI KEC KENWOOD KLOSS NOVABEAM LG (GOLDSTAR) LODGENET LOEWE LOGIK LUXMAN LXI MEGATRON MAGNAVOX MAJESTIC KONKA MARANTZ MEGATRON MB MEMOREX MGA MIDLAND MINUTZ MITSUBISHI MONTGOMERY WARD MOTOROLA MTC MULTITECH MULTIVISION NAD NEC NIKEI NIKKO NTC ONKING ONWA OPTIMUS OPTONICA ORION PANASONIC PHILCO PHILIPS PILOT PIONEER PORTLAND PRICE CLUB PRECISION PRISM PROSCAN PROTON PULSAR PULSER QUASAR RADIO SHACK REALISTIC RCA RHAPSODY RUNCO SAMPO SAMSUNG SAMSUX SANSUI SANYO SCOTCH SCOTT SEARS SPELTRAVISIO SHARP SHOGUN SIGNATURE SIMPSON SONIC SONY SOUNDESIGN SQUAREVIEW SSS STARLITE SUPRE-MACY SUPREME SYLVANIA SYMPHONIC TANDY TATUNG TECHNICS TECHWOOD TEKNIKA TELECAPTION " TELERENT TERA TMK TOSHIBA UNIVERSAL VICTOR VIDTECH VIKING WARDS WHITE WESTINGHOUSE YAMAHA ZENITH
Jun 29, 2015 | Universal Televison & Video
I have bought 2 new remotes for my centurion gate motor and the shop assistant told me how to program them.....except it doesn't work - please can someone give me step by step instructions on how to do...
On a D5 Motor To program the first remote place the jumper on in learn mode over J2 and Central Pin after it has completed flashing remove the jumper. Press the button on the remote you want to program, wait until the gate starts moving. To program addtional remotes use the master remote. First remove the jumper so that the 3 pins are exposed. Press the button on the master remote and hold it in. Notice that the LED next to the pins starts flashing after it has flashed 11 times release the button. Now press the button on the second remote and hold it in it should learn the signal.
Jan 13, 2011 | Televison & Video
Hi how can I turn off my Harman Kardon receiver with the 3.1 Dishnetwork remote?
Guest
I have provided instructions on how to program your DISH remote to a different component. I hope this helps.
Address To Other Equipment Using Code
  • Remotes: Multiple Mode Buttons (TV,VCR, AUX)
    1. Press and hold the desired Mode button until all mode button backlights come on, then release.
    2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
    3. Press the pound (#) button Note: The light will blink off after each digit is entered and then return to a steady light.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Here are the codes to try: 640, 672, 751
Ray Calo
DISH Network
Jun 28, 2010 | DISH Network IR Remote Control
Guest mailboxes will not answer
Programming on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
Enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone that has the guest mailbox
The display should say 1 Assigned, if not press 1
press feature "00" to logout
Oct 07, 2009 | Lucent PARTNER18 Corded Phone
Trying to program garage door Access Master will not program. Followed steps and now car remote will not work.
Try programming your remote this way. Press and hold the button on your remote while you press and immediately release the smart/learn button.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kidz Remote
RE: Programming a Kidz Remote by Kissel By helpmedave (Guest Post) 1x1.gifthe procedure to program the remote is as follows.
Find the setup button recessed between tv and cable buttons. Use a toothpick to press the setup button until the led blinks once, keep holding it until it blinks twice then release. press tv or cable button then enter the 3 digit code for the device you want to try. the light will blink twice if the code is valid. ( yeah i know you don't have the codes ) (me neither ) if you successsfully program it to control a device, you can then program each button as follows. hold setup button until light blinks twice.press tv or cable as needed. press 995 the led will blink twice . press the button to program. enter channel number you want (may have to enter 2 or 3 digits 08 008 etc)press setup light will blink once.m select another button and repeat to program all buttons you wish to program.to lock in settings, press setup until led blinks twice. good luck.Posted on 08/09/2007
Jul 16, 2008 | Televison & Video
Philips pc 9225
Well the switch on the left side says guest. I assume you tried this. But that is the residental...or hotel guest mode. If you are talking about menus that start at a certain volume or start on a particular channel then you need to reset them with the switch on set up.
Jun 20, 2008 | Philips RC2573 Remote Control
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid.
2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.)
3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.)
4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote.
5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid.
2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.)
3. Now Press the {NEEDED} button to program. (light will stay solid)
4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote.
5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
I sincerely hopes this helps anyone & everyone.
Feb 09, 2008 | Televison & Video
How do I reset my tv to default.
They must have them made that way so hotel guests cannot change the settings. Maybe there is a reset button on the back somewhere? I don't know of TV's having these. Some dvd players and recorders have them. It could be a small hole too that you have to press the button with a paperclip.
Thats my best guesses.
Dec 10, 2007 | Televison & Video
Televison & Video Logo
984 people viewed this question
Top Televison & Video Experts
Electro Med Services...
