Question about Minolta Office Equipment & Supplies
Paper jam copier repair for Minolta ep2152 pro,Columbus Ohio
  • Minolta Master
  • 6,696 Answers
Where is it jamming that is a very old machine has the bicycle chains in the back for some drives:) WOW I have worked on them this is a desktop one correct small
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 10, 2015
  • 3 Answers
SOURCE: paper jams minolta 1080 cspro copier
Can you explain where exactly the paper jams, just check any obstruction in the paper path, or clean all the clutches/ sensors for registration and transport
Posted on Jun 16, 2008
Cogz
  • 1326 Answers
SOURCE: minolta copier ep2152
If you are asking about a ep2152. That is a very old copier, they may not make part for it. Let's try, do you have what looks like a front view of a camera lite up orange or flashing? If so, you need a new IU unit/ drum & cln blade & developer most likely sold sepperate. I don't think they make the whole unit as one piece. I could be wrong. Try making a copy with the IU unit out. If the marks are on the blank page that comes out, it is in the fixing unit.You will need to replace the upper fixing roller & lower roller & cln roller. If you put the IU unit back in and the line is there then you have to rebiuld the IU unit. Good Luck....
Posted on Oct 18, 2008
  • 143 Answers
SOURCE: minolta cs pro 2030 copier losing developer then jams
C000 is a main motor lock code. A developer change may help. It may be two seperate problems too. The fuser unit has some drive gears that tend to break and lock the machine. This is an old analog machine, you REALLY don't need to spend much money on this one.
Posted on Jun 26, 2009
  • 1297 Answers
SOURCE: Error Code C 099b
Please check the position on the PT auxiliary tray,replace PT shifter home position sensor PC 3 and if necessary the flat cable and PCB-H.
Posted on Aug 02, 2009
  • 170 Answers
SOURCE: My minolta copier Dialta Di
maybe the paper sensor actuator is not moving or mis align
Posted on Jan 14, 2010
Where is the left paper jam Sensor in the Minolta EP 3010? My EP3010 always tells me, that there's a paper jam at the heating unit. However, there is no paper stuck at the heating unit and I can't find the...
Open the front door,remove the fusing unit(1 screw,2 connectors,ground plate wire in the back side),remove the exit lever(in this components is the exit paper actuator black colour in the right side).Change the actuator(it is damaged),and OK.
Dec 02, 2010 | Minolta EP4000/5000 CS/PRO Copier
My copier is flashing J and will not run..........what does that mean?
"J" means you have a paper jam in the copier. I would look in the fuser unit and the paper path from the paper tray for a small piece of paper left over from a paper jam... Good Luck
Sep 11, 2010 | Minolta EP1031/1031F CS/PRO Copier
Power is on, but blades dont move
What do mean about blades not moving. The machine is a legacy minolta machine. The paper draw rollers mite need replacement. does the paper leave the draw?
Apr 10, 2010 | Minolta EP1030/1030F CS/PRO Copier
Minolta ep 1054 copier paper jams and 3 appear on the panel
you mean a J3? check the fuser section the hot part. replace the parts as required
Jan 03, 2010 | Minolta EP1030/1030F CS/PRO Copier
MINOLTA EP5000 CS/PRO
Code COb31 means that the sorter didn't reset after a job. If you try doing a reset by opening the sorter as if there was a paper jam and it doesn't reset, it means that you have a problem with the sensors by the motor that turns the bins to open and clause as the paper passes. Give it a good blow with air. GOOD LUCK.
Nov 05, 2008 | Minolta EP4000/5000 CS/PRO Copier
PAPER FEED
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
Minolta ep 1030
It is not actually a paper jam - when the copier detects a malfunction, it simply stops everything. Paper jams all have "J" codes (J1, J3, etc.).
A CF3 indicates a problem with the ATDC system (Automatic Toner Density Control). The output from the ATDC sensor is outside normal specs.
Possible causes would include the copier being run (and reset repeatedly) without toner, the imaging unit not being properly installed (or not present at all), use of toner not compatible with the unit, a defective ATDC sensor or (least likely) PWB-A.
Jul 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
Paper jams minolta 1080 cspro copier
May 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
MINOLTA PAGE PRO 1250W AND 1350W
Clean rubber roller that picks up paper with isopropyl alcohol. I future, blow the dist off top sheet in stack before printing.
Feb 08, 2008 | Minolta PagePro 1350WN Laser Printer
59 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
