Hotel master remote lrc-3210p lodgenet
Which buttons do you hold to transfer master remote info to guest room remote
3 Suggested Answers
danbusa
  • 185 Answers
SOURCE: I have one receiver in my living room. The living
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Posted on Jan 16, 2011
gopakumarg43
  • 74459 Answers
SOURCE: lodgenet remote wont let me use volume of power off
Check an other setup code for your device. Some setup codes might work with certain functions. Select one setup code, which will give you maximum functionality.
Posted on Jun 04, 2012
Parental lock code put in tv. How do you cancel this? This is a hotel and set by previous guest.
restore to factory default through the settings menus on the remote control, this should clear all passwords
Jul 08, 2015 | Hisense TA42P40M 42 in. Plasma Television
I just purchased a 32 LC5DC and it came with a remote, not the original though and we cant get the T.V to pick up all of our channels--Can you do this without the original remote?
if you can acsess the tv menu you can obtain a new channel search i would take the tv back if under garentee still if you can all ways but a free view box
Dec 20, 2010 | LG 32LC5DC 32 in. LCD HDTV
I need the codes for a brightstar br100z remote for a symphonic t
Hold the set up button until the red light stays on on the remote. Press power until the TV responds. My sleep timer displayed after 23 presses (hotel room Magnavox TV). Stop pressing remote. The red light will then flash a few times once you stop. Problem fixed.
Feb 01, 2009 | Universal Remote Control Remote Control
32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Jan 17, 2009 | Philips RC2573 Remote Control
Rgb input is dissabled
If the TV has the lodgenet card installed, Which is what handles the pay per view stuff, there is no way to enable the inputs, if what they stream down from the hotel explicitly disabled the inputs. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active. Once you are done with it all, pushing the lodgenet card back into it's socket, and installing the 2 screws will put the set back to the hotel settings. Now realize once that card is pulled, you won't be able to watch the hotel's PPV or inhouse channels, only a few Free to guest channels will show up.
Dec 12, 2008 | LG 32LC5DC 32 in. LCD HDTV
Philips pc 9225
Well the switch on the left side says guest. I assume you tried this. But that is the residental...or hotel guest mode. If you are talking about menus that start at a certain volume or start on a particular channel then you need to reset them with the switch on set up.
Jun 20, 2008 | Philips RC2573 Remote Control
How do I reset my tv to default.
They must have them made that way so hotel guests cannot change the settings. Maybe there is a reset button on the back somewhere? I don't know of TV's having these. Some dvd players and recorders have them. It could be a small hole too that you have to press the button with a paperclip.
Thats my best guesses.
Dec 10, 2007 | Televison & Video
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
