Question about Toshiba 46G310U LCD TV
Picture goes black no sound
The picture goes black and no sound. When it happens I turn the TV off and back on and it is perfect for atleast and hour sometimes many hours. Is something going bad? What should I do?
romsky79
  • 822 Answers
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
Posted on May 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: tv runs for a while and then the picture goes black
Either the sleep timer is set, or the power supply unit is faulty.
Posted on Sep 13, 2009
budmrtn
  • 11361 Answers
SOURCE: my LCD tv keep going
You will need to do some troubleshooting to narrow down the causes.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 01, 2010
gopakumarg43
  • 74251 Answers
SOURCE: Sanyo 24 in flat screen
Hello
Your flat panel TVs picture tube base board has soldering loose contact with it. Just unplug your TV from AC mains socket, and open it. Pull out the picture tube base card from the picture tube neck. Pull it out straight, no shake must be there, as it will damage its connecting pins.
Normally, loose sodering are very difficult to loacate, as they will be quite micrscopic in size. Just resolder all the suspected loose sodering point on that board, by applying a little more solder. This will solve your TVs problem. OK.
Posted on May 26, 2011
Testimonial: "Going to try resoldering all the connection,as you stated only seam logical if hard to find, do them all. thank you. PS. I was not thinking..."
  • 8457 Answers
SOURCE: My Toshiba flatscreen LCD 32AV502U
U must take the tv aparts and do some troubleshooting.Tv power supply board that the board that where the tv power A/C cord plug into it.U have to check the tv power supply board carefully,see if have any dying capacitors components parts like bulging up or puffing up onto it tops?Yes? Than that ur tv problems all these dying capacitors components parts have to replaced if they're bulging up or puffing up onto it tops.If all the capacitors components parts are good and have check out no bulging and puffing onto it tops and leaking on the tv power supply board.Than the tv problem have 1 or 2 Long boards that are called LCD inveter boards are dying and the causes.These 1 or 2 long LCD inveter boards only job are to provided a backlight to the tv LCD screen panel to have picture.If ur tv the causes are the capacitors components problems on the tv power supply board and u can not replaces those dying capcitors components on the tv power supply board ur self.Try websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power suppy board for the replacement.Or the 1 or 2 long LCD inverter boards for the replacement same websites.
Posted on Aug 30, 2011
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
TV Sony sound but no picture
Hello
Check the horizontal output section. Check the LOYT [Line Output Transformer]
Mar 09, 2012 | Sony Televison & Video
JVC LT47 that picture goes black (sound fine) after being on for awhile. Can turn TV off, then back on & it's fine. But then happens again about ever hour or so.
Hello
Hello
It is due to some loose soldering points [dry soldering we say it technically], in the power supply section of the TV. Just check for it. Check the solderings of all components, that will heat up to an extent when the TV works on. Repeated heating and cooling may make solderings to the terminals of that components to get loose. Just resolder all the suspected solder terminals, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. This must solve the problem to your tV. OK.
Feb 11, 2012 | JVC Televison & Video
Picture goes black, sound OK
is it under warranty, it could be the ysus or the panel
Apr 27, 2010 | Olevia LT37HVS 37 in. LCD HDTV
TV Screen goes black
all tv has built in tuner inside,search for variables for inner tuner.when the signal is not fix naturally it goes black and white or destorted/blurred.
Oct 17, 2008 | Akai Televison & Video
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Toshiba 46G310U LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
