Question about Abbaka White Knight 38AW Electric Dryer
My dryer is not drying the clothes
My dryer is not dryin the clothes4
Ran dryer towels and sneakers didn't dry compleatly took out sneakers ran gave code AR drum turn and heats?
Make sure that the exhaust vent is not clogged! If it is, the unit will not dry anything properly since the humidity has no way of leaving the inside of the machine.
Apr 10, 2015 | Maytag Whirlpool Cabrio High Efficiency...
The drum on my dyrer quit turning
Possible problem may be broken belt or misaligned door switch. Try carefully holding the door switch closed to see if the dryer starts. If the dryer turns while manually pressing the door switch, but not when the door is closed, then the switch is misaligned. Make switch alignment to fix.
Jan 04, 2014 | Samsung DV448AG 27" 7.4 cu. ft. 11 Cycle...
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Won't dry, but get's very hot in the back
yes, unhook the vent to the back run the dryer if it heats better then either replace the venting or clean it out... hint use a leaf blower to blow that line out....... lint blockage or cloggage in the vent will reduce dryin times and yes possibly start fire... when it is on go outside to wear it vents and see or feel if it is blowin outside... hope this helps
Jan 30, 2010 | Frigidaire Dryers
My dryer not heatin up and dryin clothes hotpoint aquarius CTD00
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
We have a full video library on appliance repair video’s
Dec 30, 2009 | Hotpoint Dryers
The dryer is not dryer the cloths. I think the lint filter is clogged
Your lint fllter should be readily accessible and should be cleaned before each cycle. If this has been building up for a whle, I highly recommend cleaning the interior of the dryer. This requires removing the front panel and vacuuming the lint out of the machine.
Be careful not to touch any of the heating elements with the vac.
Also it is a good idea to clean the exhaust vent periodically. Detach the flex connection from the machine and check that it's not plugged as well. Hope this gets things dryin' again.
Let us know if you need further details.
Jul 01, 2009 | GE Dryers
New dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Abbaka White Knight 38AW Electric Dryer Logo
24 people viewed this question
Top Abbaka Dryers Experts
shaun taylor
wadingriver
wadingriver
Bill Eager
Are you an Abbaka Dryer Expert? Answer questions, earn points and help others
