Question about Goodman Heating & Cooling
Goodman ARUF 060-00A
Not heating up
4 Suggested Answers
SOURCE: goodman heat pump aruf estrips
cross check your info plate on the outdoor unit with the curcuit breaker installed in the main panel.
Posted on Jan 12, 2009
  • 1033 Answers
SOURCE: I had a goodman ARUF
Hello, Usually it has to do with the quality of the install and the brand. If it was not installed properly from the beginning then the equipment will fail prematurely. As far as the heat exchanger goes I have replaced many heat exchangers on Goodmans after 3 years being installed, Goodmans are prone to bad heat exchangers.
Posted on Mar 05, 2011
farfield
  • 462 Answers
SOURCE: I have a Goodman ARUF series air handler with a 10KW heat kit. The unit will not stop running and heats all the time. The thermastat is digital and is 3 years old.
your heat-relay aka heat sequencer, time delay... is stuck most likely remove and replace if it checks closed and no 24 volts is going to the timer portion.for 3 to 5 minutes. some of these switches stay closed for 3-5 minutes.after power is removed
Posted on Mar 03, 2012
Brand new furnace wont start its a aruf 14 electric air handler with a 10 amp heater coil
the 3 amp fuse protects low voltage side of transformer. if it's blowing on a call for cooling wire pair going to outside unit bad or contactor in outside unit.
Nov 18, 2013 | Goodman Heating & Cooling
Goodman ARUF 030-00a-1 leaking freon
spray with soap bubble solution let sit hour then check
Feb 25, 2013 | Goodman CKL36AR36 Air Conditioner
Mar 02, 2012 | Heating & Cooling
I had a goodman ARUF split system installed 8-25-09.Since then the heat exchanger blower motot replaced,cost $602.75,outdoor condenser unit fan motor to be replaced $592,00,recommend 5/8xing...
Mar 05, 2011 | Goodman Heating & Cooling
I have a heat pump model ARUF 042-00A-1A. There is only air blowing but no heat comming out. What can we do? Thanks
Heat pumps are like a refrigerator. Check the "pump" part is working properly. and is cooling one side, heating the other.
If not - maybe run out of gas (needing technical repair and refill) - or a motor fault.
Dec 27, 2010 | Goodman Heating & Cooling
I have a goodman aruf 036-00a-1. When I turn the heater on for the first time each season it smells like a burning dog. What can I do?
all heaters smell that way after a long time of not useing it, it's the lint and hair ,dust built up in the unit,clowny daggers
Nov 09, 2010 | Goodman CKL36AR36 Air Conditioner
My modle number is aruf 036-00a-1 my serial number
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Aug 04, 2010 | Goodman CKL36AR36 Air Conditioner
Goodman heat pump aruf estrips on all the time
Jan 12, 2009 | Haier Energy Star ESA3183 Air Conditioner
Connecting electronic air filter to furnace fan
You may need a "current sensing relay" to clip around the neutral wire on your blower.
Run the 120v power to the main power (the power switch- hot,neutral and ground) . Run the Hot wire through the "Current Sesing Relay" wires to the EAC unit's 120v. power input. The unit will only run when the fan is on.
Hope this helps,
Matt
Dec 31, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
