Question about Repair Manual for 1994 - 2004 Chevrolet S-10 & GMC Sonoma Pick-ups
No overdrive or drive in a 01 4l60e
When in drive pulling out it wont shift out of 2nd gear
    Sergeant:
  • 406 Answers
Could be many things but most likely shft selonoid ..unfortunately it is located inside the trans and must me taken apart.good luck
Posted on Oct 03, 2014
1999 mitsubishi eclipse automatic transmission wont shift into 4th gear.
First off.. If you have a check engine light on, Find someone with an OBD2 READER or buy one yourself(very good tool to have) and that will give you the code(s) to your problem..
If not.. Check ALL your fuses..
If those are good and you DO NOT have a sealed tranny.. Check your fluid..
If all the above check out good.. It's gonna be 1 of 2 things..
1. Your overdrive is either turned off and/or damaged.. (Over drive on: uses all 4 gears/Over drive off: uses only 3 gears)
2. Your shift silonoid pack is damaged, which normally when this happens your car goes into a thing called "dummy mode" and keeps the tranny ONLY in 2nd gear..
Now assuming your car shifts into every other gear just fine.. And the fact that normally reverse is the first gear to go out.. I'm gonna say it's your overdrive or a relay that runs with your overdrive..
Let me know what happens or if you have anymore questions..
-Daniel
Proud Owner of the
sickest 97 eclipse.
Sep 28, 2014 | 1999 Mitsubishi Eclipse
Is it ok to start off in 2nd gear and manually shift up to 3rd and then overdrive?
You can put the shifter in 2, 3, or overdrive. It will still start in first and shift up to whatever gear you have selected. Try it, you wont damage anythingl
Oct 22, 2012 | 1996 GMC Yukon
Shifting problems 02 Dodge Durango 46re
shift solenoid needs to be replaced or the speed sensor
Oct 18, 2012 | 2002 Dodge Durango
My 1995 nissan quest overdrive light comes on when i start it and it wont go in drive but will 2nd gear, sometime on can turn the van off and restart and it will go in drive and shift ok but it shifts...
Sounds like the sensor for first gear.
The transmission comes with a shift sensor for each shift: if 4 shift, 4 sensor (including reverse).
Have somebody check the sensors and the cpu for the tranny. They go hand to hand.
Jun 28, 2017 | 1995 Nissan Quest
1999 Durango starts out in 2nd and shifts into drive fine regardless of what gear is selected. Even if 1st is selected, starts in 2nd. Reverse is fine. Will not shift into final or overdrive. Govenor...
I don't have the shifting schematics for THIS vehicle .
However, they are available in the vehicle's repair manual. If you obtain this manual look for what is common between 2nd gear, final drive and overdrive this is your problem.
Remember they source of the problem may require a rebuild of the transmission. You may want to save some time and just give it to a repair shop.
May 18, 2010 | 1999 Dodge Dakota
4l60e going from 1st to 3rd and dont have overdrive any more
You most likely have a broken sunshell inside the transmission. They tend to go out when the transmission is shifted to drive when while still rolling in reverse.
Dec 28, 2009 | 1994 Chevrolet C1500
I have a 1995 GMC Jimmy with auto trans., it wont shift into 2nd gear only shifts into drive when I get up to 2700 RPM and let off the gas and wont shift into overdrive at all. Does anyone know what causes...
Your going to have to get the Jimmy scaned before youhurt the transmission, It sounds like it's on a Limp mode which can range from a tune up to a bad ground. Good luck.
Mar 17, 2009 | 1995 GMC Jimmy
1988 bronco automatic transmission
3rd and 4th gear clutches are the same. The overdrive section is worn out thus resulting to this problem. have the transmission repaired with a new overdrive section.
Mar 05, 2009 | 1988 Ford Bronco
Repair Manual for 1994 - 2004 Chevrolet S-10 & GMC Sonoma Pick-ups Logo
60 people viewed this question
Top Haynes Vehicle Parts & Accessories Experts
Vernon Taylor
 Mikey
Mikey
Howie Snyder
Howie Snyder
Are you a Haynes Vehicle Part and Accessory Expert? Answer questions, earn points and help others
