Question about Friedrich Heating & Cooling
Air conditioning fan stuck
Air conditioner fan stuck
    Genius:
  • Friedrich Master
  • 1,363 Answers
Have to replace motor
Posted on Sep 05, 2015
Benimur
  • 6966 Answers
SOURCE: air conditioning
Fan problem could either be the starting capacitor or the motor itself. Often it would just be the capacitor and you could verify this by a humming/vibrating sound coming from the motor as if trying to turn but is not capable of. If it were the motor burned, the unit would have excessive current tripping the breaker or a fuse blowing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 13, 2008
  • 127 Answers
SOURCE: My RV rooftop air conditioner fan has seized up
Whether to replace the entire unit or repair it is a tough decision. If the unit is not very old and was working fine before the fan motor froze up, then I do not think that it is necessary for the entire unit to be replaced. With a new unit of course comes the new warranty.
It is not difficult at all to replace the upper unit of the air conditioner. What you have to look for and make sure of is that the ceiling pack or Air Distribution Box (inside unit of AC) that you currently have is compatible with the new Upper Units. Get the part number off of the inner unit and make sure that it is compatible with the part number of the new upper.
Again, it is much less expensive to replace the fan motor than the entire unit (especially Dometic). You could replace the fan motor and get another 10 years out of the AC or, you could replace it and only get 1 year out of it. That is your call.
Just a word of precaution. Dometic Air Conditioners are very hard to find right now due to an industrial accident that occurred at the AC plant. Most distributors and service centers are 6 to 8 weeks out on getting a Dometic AC in stock. That is something else to think about.
Hope this helps,
Jeff
Posted on Jul 06, 2009
  • 233 Answers
SOURCE: GE Air conditioner cannot kick into airconditioning mode
it sounds like either the start components for the compressor have failed or the compressor itself has failed, since it is not kicking the breaker I would lean towards start components.if it is a PSC only comprssor, you may be able to add a start assist to get the compressor started. I assume that since it is 8000 btu it is 110VAC you can probably get a generic start kit at your local appliance parts house. they have a diagram and are fairly easy to install, just be aware that the capacitor storea charge on the OFF cycle, and can be dangerous
Posted on Jul 19, 2009
wise_jf
  • 66 Answers
SOURCE: I cannot get my wintair room air conditioner to
It sounds like your air conditioner is doing what it is supposed to do. The compressor kicking in and out is an energy saving method of using the ac. When the thermostat (ball attached to evaporator coil) registers the set temperature the compressor kicks off.
Posted on Jun 28, 2010
heatman101
  • 43501 Answers
SOURCE: air conditioner isn't very cool
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioning2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jul 12, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
The fan still running when the air conditioning stop in auto set mode
fan relay stuck if its on all the time. some use time delay to get the last bit of cooling off indoor coil then shut down
Aug 27, 2013 | Goodman CLJ30AR32 Air Conditioner
Pro Standard Fan mount
Since the failure of an air conditioner to turn on, loss of air conditioner cooling capacity, reduced air conditioning output temperatures, loss of cool air supply, or even loss of air flow entirely can be due to a variety of problems with one or more components of an air conditioner or air conditioning system, after reviewing the lost air conditioner cooling diagnosis procedures described in this article, be sure to also review the diagnostic procedures at each of the individual air conditioning diagnosis and repair major topics listed just below. To return to our air conditioning and refrigeration home page go to AIR CONDITIONING & HEAT PUMP SYSTEMS.
Electrical problems on HVAC systems: Keep in mind that despite the depth of technical detail you will find here about all components of air conditioners and heat pumps, most service calls for non-working air conditioners or heat pumps turn up an electrical problem. So if your A/C system is just not working at all be sure to check all of our electrical and control setting suggestions first.
Mechanical problems on HVAC systems: tend to fall into these groups: refrigerant leaks, dirty condenser coil or unit, dirty evaporator or cooling coil, or burned out (or hard-starting) compressor motors. We have also seen a number of problems with fans and fan motors in both the compressor/condenser unit and in the air handler/blower fan unit. Some of those fan problems are mechanical - like a loose fan belt or blade. MORE DETAILS
Nov 13, 2012 | Heating & Cooling
I need an air intake fan for model # PLM 14000E---new unit but the fan broke into pieces
The company manufactured air conditioners, small portable and environmentally friendly air conditioners for over 50 years. The company is no longer operational and no longer produces air conditioning units.
If you have the pieces any good air conditioning service company may be able to get you an "off the shelf" generic replacement fan. They may require you to pay for a service call and for their time looking for a replacement part. good luck.
Jul 11, 2012 | Heating & Cooling
Goodman air conditioning not blowing cold air, fan outside fell off?! screw is broken and stuck inside the fans! Please help, house at 86 downstairs and 90's upstairs. No maintenance till Monday at...
Hello
I dont know how handy you are but.You can shut the main circut breaker off for the a/c unit.
Then remove the cage or cover for the outside fan.Usually a screwdiver or nut driver will do the job.
Once you can get to the fan, remove broken screw.
Your local hardware store should have another screw or something similar.
Sep 18, 2011 | Goodman CLQ36AR49 Air Conditioner
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
Will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Jun 03, 2008 | Dometic Rooftop RV Air Conditioner
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
