Question about Microsoft F-16 Fighting Falcon Flight Simulator - Windows
F-16 serial key - Microsoft F-16 Fighting Falcon Flight Simulator - Windows
Fifa 16 serial key
sorry only Fifa can assist you .
Nov 09, 2017 | FIFA Video Game Consoles & Games
What is a browning sweet 16 serial number 5s-40407 worth
we do not appraise guns here contact a local gun dealer
Mar 04, 2017 | Optics
How can i find a license key for this http://crackmania.net/2015/01/reimage-pc-repair-serial-key-crack-full/ reimage pc repair???
it is usually a 16 digit number stamped on the BOX .and to use the program you must have that key number not an actual metal key
Mar 10, 2015 | Microsoft Computers & Internet
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
Magix serial number
Contact Magix directly to validate your software.
Apr 28, 2017 | Computers & Internet
Serial number 16370112
1984
Marlins after 1948 use a system where you subtract the 1st two digits of the serial number from 100, to get the LAST two digits of the year it was made.
In your case, serial number 16370112 - 1st two digits = 16
100 - 16 = 84 = 1984
Jan 29, 2014 | Marlin Model 60 .22 Cal Rifle
Corel Wordperfect X6 V 16 serial key and activation code
Why should I provide you with them if this is illegal absolutely.
Apr 12, 2013 | Computers & Internet
Sir plz send me original serial and code for Magiz movie edit pro 16 plus or methd of registered this softwares. I am waiting Thank you
Downloading these three files will give you the answer to your problem, they include a key generator that can be used to generate a key for it...
Feb 28, 2011 | Computers & Internet
MY RECENTLY BOUGHT LAPTOP IS BEING REFUSED THE WINDOWS 7 UPGRADE BECAUSE THE SERIAL NO.IS SAID TO BE INCORRECT.I HAVE REPEATED THE NUMBER MANY TIMES FROM THE WHITE LABEL. LXPCEOX1409211243112000 PURCHASED...
Hi Ron,
Is it asking for a serial no. or a product-key? The upgrade should have come with a Product-key. It would be formatted in the same way the upgrade program asks for it.
For example: xxxxx-xxxxx-xxxxx-xxxxx-xxxxx
Check again. Or comment back with more details about what is happening.
Mike
Nov 10, 2009 | Acer Aspire 5500 5570-2609 Laptop
Microsoft F-16 Fighting Falcon Flight Simulator - Windows Logo
74 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
