Question about Dryers
LG DLE2301R, MY DRYER'S CONTROL PANEL LIGHTS WONT COME ON,BUT THE LIGHT INSIDE THE DRYER IS ON.COULD THERE BE A SAFETY BUTTON THAT NEEDS TO BE PRESSED.I JUST RECENTLY MOVED AND I HAD TO CHANGE THE WIRING FROM TRHE THREE WIRE SETTING TO THE FOUR WIRE SETTING TO BE COMPATABLE TO THE OUTLET IN THE HOME.
Master_Tech
  • 770 Answers
SOURCE: changing four prong dryer to three prong outlet
use the ground on the machine.....There are 3 wires on the terminal block if you notice there is a grounding strap off the center post this will act as your ground to the machine back in your panel box the center post leads to ground anyway the other 2 are hot leads (240vac) use the 3 post you will be fine. you will be grounded let me know if you have any problems
Posted on Feb 19, 2008
  • 30 Answers
SOURCE: Whirlpool Dryer wont start
Possible door s/w or thermal fuse. If its blowing thermal fuses with a clean and avg vent run check the relay, cycle unit with no heat fuction if the heat still comes on replace the relay board. Call your local servicer.
Posted on Mar 17, 2008
  • 109 Answers
SOURCE: inside light works, no lights on control panel
replace control panel.
Posted on Mar 28, 2008
SOURCE: Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Posted on Jul 10, 2008
  • 74 Answers
SOURCE: our whirlpool Duet dryer has three prong plug and
Some local codes require a separate ground and neutral wire. You are probably in one of those areas. Just to keep things code compliant go ahead and replace the 3 prong with a 4 prong cord.
Posted on Jan 01, 2010
Why does high limit switch keep blowing?
Check for lint build up inside the machine, especially around the air exit duct as any restrictions can cause the machine to build up heat higher than normal. The high limit safety is a fire preventative device.
Nov 15, 2015 | LG Dle2301r Front Load Dryer dle2301r
LG - DLE2301R no power
No reset button You have a non resettable safety stat that may have opened checking your model we will post what we find later
R.A.P. 843-813-6519 appliance tech.
part you may need PART NUMBER: 6931EL3003D
Oct 21, 2013 | LG DLE2532W Electric Dryer
LG DLE2301R will not shut off
More than likely a bad timer. The timer / board will probably run you around $125. Time for a new dryer???
Jul 25, 2012 | LG Dle2301r Front Load Dryer dle2301r
Model DLE2301R LG dryer. I think the 15 amp circuit board fuse is blown because th wife dropped a fork when cleaning the lint filter cavity. The dryer made a noise and shut down, she turned the drum and...
check to see if the dryer is getting power, and you will have to open the dryer up and remove the fork, Disconnect Power First. I am assuming that something shorted out, so check the main fuse. Tim
http://www.ehow.com/how_6437684_open-front-panel-lg-dryer.html
http://lgrepair.info/dryer_repair_los_angeles.shtml
Jun 04, 2011 | Dryers
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Dryer
sometimes the control knobs that you set your dryer to different heating sets will go bad but it is in the control panel some where i whould say it is the heating setting
May 19, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Dryers Experts
