Question about Nespresso D90 Essenza Single-Serve Manual Espresso Machine - Mint Condition
Nespresso Claw not piercing pod
Claw doesn't fully pierce coffee pod
5 Suggested Answers
  • 1833 Answers
SOURCE: Nespresso C190 is not piercing the top of the
According to your problem first open the coffee container and clean it properly. After cleaning fill the container with proper quantity of coffee beans. May be the spout holes are blocked. So clean the spout by pin. Also make clean the infuser by open the front cover of the infuser. The ground coffee may be blocked in the funnel. Remove the ground coffee inside the funnel using a knife. Then clean the infuser and the inside of the appliance. Descale the machine. It will help you.
Posted on Jun 13, 2011
SOURCE: The pods are not being
The capsules are not pierced when they are inserted. They are pierced on the back but not in the foil. The foil is pierced when the hot water is injected through the posterior holes and the pressure causes the foil to bulge, thus getting pierced by the grid in the front of the machine. If the capsules are not getting pierced it means that the water is not being injected with enough pressure. This could be due to hard water deposits. Try first to pump the machine by turning it on and then lifting the lever and keeping it raised for a few seconds. If that doesn't work, de-scaling the machine should correct the problem.
Posted on Sep 16, 2011
SOURCE: No coffee comes out, only
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
Posted on Dec 13, 2011
  • 6 Answers
SOURCE: My Nespresso Magimix Citiz does
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
The water does not flow through the spout. Can this be fixed or is it cactus?
YOU MAY FIND CACTUS IN THE GARDEN BUT YOU COFFEE MAKER NEEDS TO BE CLEANED OUT TRY CLEANING THE SPOUT FROM OUT SIDE WITH A LONG NIDDLE LIKE TO CLEAN THE CHANNEL PLUS RUN SOME WORM WATER TO MELT IT DOWN
Nov 14, 2015 | Nespresso U D50 Espresso Machine with...
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
Coming out in short spurt will not coffee cut up
there are a few things that can cause this;
1) You may need to clean the needle in the coffee exit where the coffee pod sits and gets pierced when the top is closed. You do this with a needle, be careful the point of the piercing nozzle is sharp and the needle point is as well.
2) There is also a needle in the cup holder under the pod that cuts the hole for the coffee stream, this needs to be cleaned with the needle.
3) The filter in the water tank may be plugged and needs to be cleaned.
4) The pump may be clogged with lime and scale.
5) The heater element may be scaled with lime.
6) Items #3 to 5), to fix this use DE-scalier, or vinegar solution, the pickling strength works better than household variety, but both are OK.
7) run the cycle for coffee, no pod, 3 times, this should clear the taste of the vinegar.
Hope this is your solution.
Mar 17, 2015 | Keurig B70 Coffee Maker
Why my nespresso c110 cofee machine will not pierce the top of the pod and thereFore no coffee.
Are you using genuine Nespresso capsules? Any other kind will cause the machine to malfunction.
Feb 13, 2015 | Nespresso Coffee Makers & Espresso...
What are coffee pods? Someone told me to use them in my coffee machine?
Some coffee machines have the option to either use ground coffee and filters or coffee pods. These are small, sealed containers that have the ground coffee inside. You insert the pods into the machine and click them into place. The machine pierces a hole and the water drips through. It's a much tidier way to make coffee especially if you don't drink a lot of it, so you don't want a whole jug full, rather just one cup at a time.
Feb 25, 2013 | Home
The pods are not being pierced and the coffee is coming out too weak. Help!
Aug 10, 2011 | Nespresso Essenza D100 Espresso Machine
Recently the machine started dispensing VERY weak (mostly water with a very light brown see through color) coffee. It does not happen every time although all coffee seems weak. It looks like the pods...
Hi imhofag,
The first thing to do is clean the projections on the piercers. Gunk will build up on them and they need to be cleaned periodically.
I would need your model number in order to help you take it apart.
Please reply if cleaning the projections doesn't help.
Thanks,
Handie Andie
Jun 11, 2011 | Nespresso Coffee Makers & Espresso...
Every light blinks and it won't heat water a braun tassimo coffee maker
just posted this solution to another problem. there is something on the glass bar code reader up where you insert the t-disc - or the water vessel is not properly seated in the base of the coffee maker.
Check both.
Nov 04, 2009 | Braun Tassimo Coffee Maker
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Coffee Doesn't Brew
You may have gotten a unit that is minus the piercing apparatus. The little plastic piece with the piercer may come off with the used pod. This never happened to us but my daughter-in-law did, and apparently threw the piercer out with a used pod. They were able to order the part which seems to be easily removable - actually they ordered two while they were at it. Their coffee maker is working just fine.
Mar 18, 2008 | Braun Tassimo Espresso Machine/Coffee...
Nespresso D90 Essenza Single-Serve Manual Espresso Machine - Mint Condition Logo
23 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
