Question about Samsung Washing Machines
Wf8804rpz, machine dead
No fuses blown.
My Audiovox mobil chef microwave went dead fuses in house are fine. Stumped ?
there are fuses in the machine itself that can blow
I suggest that you have it inspected by an accredited appliance shop as if the fuse is blown it points to something more serious.
May 24, 2015 | Audiovox Microwave Ovens
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
I have a Bosch washing machine WFVC5400UC and the digital display does not come on and it seems like it is not getting any power. I have tested the outlet and it is good. Can you help?
hello if total dead check the glass fuse inside the washers power supply if blown make sure you use the same rated fuse if blows again then you have a dead short somewhere hope it helps
regards
shaun
Jan 07, 2011 | Bosch WFVC5400UC Washer
No power to my washing machine (fuse changed still no power)
hello, have you checked the glass fuse inside the power supply if it has blown make you use the same rated fuse if it blows again the you have dead short in the washer somewhere hope it helps
regards
shaun
Jan 03, 2011 | Zanussi FC1200W Front Load Washer
Machine dead, not starting
hello, i take it you've checked the fuse in the plug if ok then check all the wire connections if ok then it's possible that the glass type fuse in the washer power supply may have blown. make sure you use the same rated fuse thanks
regards
shaun
Dec 04, 2010 | Hoover UltraCare HC6 150M Front Load...
Washing machine powered on and went dead suddenly after less than a minute. no lights, no sound, nothing ever again.
you have blown the fuse inside the control panel remove the top panel which has all the buttons on it (should just be a couple of screws on the back) then take out the fuse and check if it is blown then go and buy the exact same fuse and you should be right
Jan 21, 2010 | Samsung Washing Machines
Dead, replaced battery and still dead
your fuse is blown near the battery is a fuse check if it is blown
Jul 24, 2009 | 1995 Suzuki VS 800 Intruder
2000 Mazda MPV radio is "dead"
try pulling all the fuses one at a time and see if any others are blown. if so replace.
Jun 23, 2009 | 2005 Mazda MPV
Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Sep 16, 2008 | LG WFT1071TP Top Load Washer
Is there a fuse inside the L800
You probably have a dead low voltage power supply.
There might be a fuse on it, but a blown fuse usually indicates a bad power supply.
Sep 02, 2008 | Canon FAX-L800 Plain Paper Laser
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
