Question about Brother LB6770 PRW Computerized Sewing Machine
How to do satin stitch on brother LB 6800 - Brother LB6770 PRW Computerized Sewing Machine
What is the setting for satin stiches
Depends on your machine and the thread you are using. A satin stitch is a zig-zag with the stitch length set so the fabric is not visible between the stitches but the stitches do not overlap.
Satin stitch Wikipedia
Jun 26, 2017 | Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
Is a satin stich programed in the machine.
Perhaps newer machines have it, but usually the sewists programs it. All it requires is a wide stitch and short stitch length. The length is adjusted so the thread actually covers the fabric between stitches, but does not overlap itself. Even if the sewist has a programmed satin stitch but there may still be some required adjustments needed since the thickness of the thread will alter the way the stitch looks.
Mar 20, 2016 | Sewing Machines
How do I satin stitch h on a Bernina 1130s limited edition?
Satin stitch is a very wide zig-zag stitch with a very short stitch length. I do mine by dropping the feed dogs and guiding the material through by hand (a lot like darning).
Jan 30, 2015 | Bernina Sewing Machines
What can I do to widen my satin stitch when it is to narrow for the applique
Unless you have and know how to use digitizing software, will you be able to add width to the satin stitches when doing applique. You need to cut the applique fabric larger than the cut-out-line so the applique fabric will held down properly. Some Commercial or higher end home embroidery machines can re-interpret the embroidery design and widen the satin stitches in a design without software. 6f3dbcfe-19c3-4021-b143-de10c9a89868.jpg
Jul 14, 2014 | Brother PE770 Computerized Sewing Machine
How can I add a few satin stitches to a design
You need some software that can import the design and then add your stitches. Optionally, you can figure out the proper location and design the stitches to run in a separate pass. Either way you need digitizing software.
Aug 27, 2013 | Brother PE770 Computerized Sewing Machine
I don't know how to make satin stich Janome DC2010
As a general rule of thumb, satin stitch is obtained by selecting zig-zag, turning stitch width up to 3 or 4 and stitch length to 0.5. If you have a clear plastic open toe sewing foot, put that on to help view the area.
If you are doing applique (attaching pieces of fabric to another surface) with a satin stitch, you may also need to use tear away stabiliser underneath or interface the fabric first, it depends on what/where you are doing the satin stitch onto.
And a nice machine embroidery thread will give you a much silkier appearance than plain thread.
Mar 13, 2011 | Sewing Machines
Brother LB6770 PRW Computerized Sewing Machine Logo
43 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
