Question about Taco SR504-2 4 Zone Switching Relay
Loud buzz when engaged
Taco SR 504 emits loud buzz when zone 2 engaged. Turns off when zone thermostat lowered.
I have a hot water system that uses baseboard heaters with two thermostats. the pump is activated through a Honeywell R845A. Is the R845A the problem?
Using that thermostat on a boiler system requires a relay to be installed. like the Taco sr-501 or an Argo AR-822
Jan 27, 2016 | Thermostats Heating & Cooling
Need to replace a taco zone valve head
Should be able to swap them., or get a qualified tech. to do it.
Mar 04, 2014 | Taco 3/4" Gold Series Zone Valve 571
Honeywell Strat RTH9580 reboots continuously when connected to Taco ZVC406 transformer
Might be a load that's too heavy for your stat. Consider installing an isolation relay.
Feb 18, 2014 | Taco Zvc406-exp-4 Boiler Zone Control,6...
One of my heat zones doesnt close when the thermostat is OFF.
If the circulator pump is not running It may be that another circulator pump is forcing boiler water through that zone when it runs,if so , you may have to install a zone valve to make sure the zone is completely closed off when not in use. Hope this helps.
Dec 31, 2013 | Heating & Cooling
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 06, 2012 | Rheem Water Heaters
I need help with a buzzing sound in my air conditioner.
It is probably the compressor humming. They can make some funny noises especially on start for a while. If the unit is not cooling it may be the start capacitor or the comressor may be locked up.
Jul 19, 2010 | Goodman CLQ36AR49 Air Conditioner
Programmable thermostat for Taco zone valve
Hi there, this mechanical t-stat you are using now, does it just open and close this zone valve on a call for heat to fire the burner also? What voltage is this thermostat, 24, 120, or even 220 volts? I need to no this so I can locate the stat you need to replace the old mechanical stat. Let me know exactly what all this stat controls, any fan, or just the burner and zone valve. I need to know the wiring configuration of the existing stat. This will make for a faster locating of the new stat. I can get you a stat that you can control just about any combination's of what ever and that's why I need to know voltages and amount of wires available to me to work with. This I thank you for. Contact me and I will get to you as soon as I am available today.
Sincerely,
Shastalaker7
Jan 17, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Jul 30, 2009 | Microwave Ovens
Taco SR504-2 4 Zone Switching Relay Logo
73 people viewed this question
Top Taco Plumbing Experts
Gil Shultz
Are you a Taco Plumbing Expert? Answer questions, earn points and help others
