Question about Frigidaire Stove/Oven/Range Cooktop - 318079348
Changed my bake element now both Bake and Broil elements don't heat up
My bake element shorted out, changed it, now both Bake and Broil elements don't heat up /stat up
Dcs oven wos130 wont reach set temperature on bake
Good afternoon Steve!
The answer may depend a bit on what you mean by 'stops heating'.
  • One interpretation could be 'the heating shuts off, and the oven goes back toward room temperature
  • The other would be that it heats up, but it heats to a certain temp and then stays there. it's just not as hot as it's supposed to be.
If it's the former, that sounds like something is overheating and an interlock is engaging because it's interpreted as 'I'm too hot where I shouldn't be, and I should shut off before I cause a fire. I'd leave that to a better trained service tech.
If it's the latter, then it'll depend on how low it is. If it's way low, then there's a couple possibilities:
  1. The heater element is defective, and even at the full current draw the oven can run, it can't get any hotter than that upper temp. This would mean replacing the element.
  2. The temperature sensor in the oven is defective or mis-mounted. There should be a temp sensor inside the oven cavity. if it's disconnected, or, say, bent out of place and much nearer the bake element then it should be, then the heat coming direct off of the element may be fooling it into thinking the oven is hotter than it really is. this could mean replacing the temp sensor, or just re-mounting it to proper position.
If it's just a bit low, then there could just be a calibration problem. If you look at the manual here
DCS WOS 127 Use And Care Manual Child Safety User Option you can see how to adjust the calibration up or down in temperature to, hopefully, match the oven thermometer you're trying to use as a check.
Hope this helps!
Good Luck
D
Nov 18, 2015 | DCS Wot-130 30" Wide Single Electric Wall...
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
I have FGES3065KFA gallery and I have baking problems. It bakes outside of the cake but inside of the cake stays raw. Me and my husband check the bake and broil element they work fine. We change the...
read the mixture instructions
try preheating the oven for the required temperature or when the thermostat turns the light off
insert the cake to be cooked and leave it there for the desired time
Too hot will burn the outside with out cooking all the way through
check the ingredients carefully as if the mixture is too wet ( butter, milk, water all make it wetter than required )
Place the cake in the center of the oven ( not on the bottom shelf or the top shelf)
All these may sound mundane but they all point to getting a good cake result
Sep 14, 2015 | Frigidaire FGES3065KF Gallery 30" Slide In...
We set the ovens to bake, they click but do not heat up.
Could be the elements.if it is a fan oven the elements sit behind the rep late.first check the fuse box.then if the oven lights up it could only be the elements.they are easy to replace .you can buy the replacement units off eBay.you can also watch a tutorial on replacing them on YouTube.
Jan 18, 2015 | Electrolux Frigidaire Gallery 30" Double...
I have a Maytag slide in electric range model MES5770AAB.
can not really say what is might be but here is link to diagrams and parts list Parts Model MES5770AAB Sears PartsDirect
Sep 13, 2014 | Maytag Slide-In Electric Range
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire FEF368GC
Top burners work,broiler works,oven does not
check and make sure the bake element has continuity.If there is not continuity with your ohm meter then replace the bake element.
If it tests good the replace the main Electronic control board or the oven switch which ever the unit is equipped with
Feb 23, 2010 | Cooktops
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
Aug 02, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
JENN AIR WALL OVEN ELECTRIC
Are you sure the breaker didn't trip on one side? If one leg of the 220 is out, the lights and controls will appear to work, but the elements will not heat up. Make sure you have 220 to the appliance. It's also possible that you pulled a wire off somehow when changing the broil element.
Dec 12, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Sve47100 oven doesn't heat
Test the swtich w/ multi tester /connect tester as a jumper to the switch dettach one line on and off switch /if does not reponse / replace the switch.
Jan 03, 2008 | Jenn-Air JED8430 Electric Cooktop
Frigidaire Stove/Oven/Range Cooktop - 318079348 Logo
59 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
