Question about Duraflame Heating & Cooling
What kind of replacement bulb for duraflame heater
The heater works in my Duraflame Electric stove heater DF1-3108 but the flames wont display. There is no separate panel in the back of the unit to access a light bulb. Can you help?
There may be an access panel in the front for the light? You might have to have a good look for a panel that can be removed. Make sure its unplugged before getting into it.
Nov 19, 2016 | Heating & Cooling
My flame quit working in my red core heater.
Amazon.com - Redcore S2 IR Stove Heater - Space Heaters
www.amazon.com/Redcore-S2...Heater/.../B008QJV9...
Amazon.com, Inc.
Rating: 3.7 - ‎29 reviews
Buy Used and Save: Buy a Used "Redcore S2 IR Stove Heater" and save 68% off ... The flame is very realistic - my son and his friend thought this heater was a real wood stove. .... Also, the door was broken off the hinges when we received it.
FAQs About PowerHeat - DURAFLAME ' TWINSTAR ...
www.twinstarhome.com/duraflame/pages/faqs/index.html
What is quartz infra-red heat? ... It seems that the thermostat on my PowerHeat is different from what I believe the actual room temperature to be. ... When the heater isnot running, PowerHeat periodically runs a temperature accuracy test.
Customer Reviews: RedCore Concept S-2 Infrared Stove ...
https://www.walmart.com/reviews/product/22070668
Walmart
Jan 10, 2016 | Heating & Cooling
I have a 240 v duraflame celling heater .and it won't turn off even at the lowest setting.
the contact's in the thermostat have fused together. You need to replace the thermostat before using the heater.
Feb 15, 2015 | Heating & Cooling
Lightbulb is not working how to replace
theheaterisjustthreeweeksoldanditwasrunningfineuntilthismorning
Feb 26, 2014 | Duraflame Heating & Cooling
My Duraflame heater model dfs-550-0 , heats well but my flames no longer work . is there anything I can do to fix this problem? someone please help!
Actually, it could just be a burnt out light bulb. Open the back. The light bulb is easy to get to and easy to replace.
Aug 27, 2013 | Heating & Cooling
MY DURAFLAME HEATER COMES ON BUT ONLY BLOWING OUT COLD AIR?
Sounds like something in the control module. I have 2. One bought used about a year old. Lasted about 3 months and something in the control module or panel died so would not light or power up. I hard wired the blower and Infrared bulbs to manual switches so I can manually turn on and off heat. Have separate switches so can leave the fan blowing after turning off the elements to allow them to cool. The other heater was bought new and laster about a year and a half. Then the thermostat reading worked and fan worked cycling as should but elements would not light. Did a factory reset holding power button while plugging in. That fixed it for a day then back to same. took back off and while trying to trouble shoot voltages on the power supply module the elements started working again. Not sure what the issue but seems to be a definite issue with short lived control modules. To date have not found a resource to buy new control boards or other replacement parts besides bulbs which with the fans seem to be the most durable part of the whole heater.
Feb 20, 2013 | Duraflame Heating & Cooling
Duraflame heater runs for 5 mins and shuts off
try cleaning off the filter that is on the bottom in the back of the unit. It is a fail safe sensor that in the event the unot overheats it shuts off the heater. Worked for me on mine.
Oct 06, 2012 | Duraflame Colby Indoor Infrared Quartz...
Heating & Cooling Logo
94 people viewed this question
Top Duraflame Heating & Cooling Experts
L Pfaff
L Pfaff
David Payne
David Payne
Caleb Brunson
Caleb Brunson
Are you a Duraflame Heating and Cooling Expert? Answer questions, earn points and help others
