Question about TDK ProDigital (N4300) Network Adapter
Promise n4300 problem - TDK ProDigital (N4300) Network Adapter
Is it worth what they promise?
lol, is what worth what promise? This is all you give us to help you!
Question about Cars & Trucks
Is it worth what they promise? Posted by Fern on May 03, 2016
May 03, 2016 | Cars & Trucks
Google com
BigFishGames currently has Settlement: Colossus listed for $2.99 which is like 70% off the normal $9.99 price.
Settlement Colossus
Same deal for "The Promised Land" $2.99
For both, remember to use promocode: NEW299
The Promised Land
Jun 22, 2014 | Computers & Internet
64 bit driver promise ultra
There is no official Window 7 driver for the Promise Technology Ultra 133 TX2, but you can use the Vista driver. It should also work for both the Ultra 66 and the Ultra 100 cards.
I found the Vista driver at:
http://www.promise.com/single_page_session/page.aspx?region=en-US&m=722&sub_m=sub_m_9&rsn=144
The file name is: Ultra133 TX2 windows 2.1.0.3 logo driver.rar
This file is compressed in the rar format. I decompressed it using 7-Zip. Folder amd64 contains the 64 bit driver. The amd64 driver worked even though my mother board has an Intel CPU and chip set.
Oct 31, 2013 | Promise Ultra100 ATA/100 Pci (ultra100 tx2...
I need drivers for fastrak sx4100 for windows seven
There only seems to be one set of drivers available from Promise
http://www.promise.com/single_page_session/page.aspx?region=en-global&m=719&sub_m=sub_m_8&rsn=144
If this doesn't work in Win 7 try installing it in XP mode and see if that does the trick
Mar 23, 2011 | Promise FastTrak SX4100 Serial ATA RAID...
I want serial number for after effects cs3 now
So if I give you my personal, private - bought with serious money serial number here, you absolutely promise not to share it with anyone?? Ok. Here comes: 774362941043758 Promise is a promise...
May 28, 2010 | Adobe Premiere Pro CS3 Full Version for PC...
Promise FastTrak TX2300
You will need to download the drivers on to a floppy disk. When loading setup press F6 when it asks if you want to use third-party RAID controller.
You can get the drivers from the below link
http://www.promise.com/support/download/download2_eng.asp?productId=136&category=driver&os=0&go=GO
Oct 25, 2008 | Promise (FASTTRAK TX2300-5PK)...
Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Aug 09, 2008 | Promise Ultra133 TX2 ATA Controller
K8T Neo Motherboard with Via and Promise SATA problems
http://www.versiontracker.com/dyn/moreinfo/win/140882
the above site has driver via Hyperion pro 11.5mb
http://www.soft32.com/download_170761.html
This one has promise fast trak driver
Hope this helps please post rating thanks
Aug 01, 2008 | MSI K8T Neo-FSR Motherboard
Promise NS2100 Drivers
I didn't resolve the problem,and I thought this was public forum not a paid subscription issue
Apr 03, 2008 | Promise (NS2100)
TDK ProDigital (N4300) Network Adapter Logo
24 people viewed this question
Top TDK Computers & Internet Experts
David Payne
David Payne
Are you a TDK Computer and Internet Expert? Answer questions, earn points and help others
