Question about Motorola Mobility W385 Cellular Phone
Change cb# stored - Motorola Mobility W385 Cellular Phone
Brand new Midland 5001z 40 channel cb blows fuses its turned on
Where did you buy the radio at? Can you return it to the store? If you purchased it at a big box store, like Walmart, they will take it back without a receipt on an exchange.
More than likely the radio was wired backwards by someone, which blew the protection diode, and then was returned to the store and put back on the shelf.
If it is just a blown protection diode, it is only a $10 fix at most any cb radio shop.
If I can help anymore, please let me know.
Dean Pitts
Rollin CBs
dean@rollincb.com
Feb 05, 2012 | Radio Communications
Need Power cord
Radio Shack carries replacement cords. Most truck stops have a CB section in their stores where you could pick one up, then of course there's always ebay!
Jun 11, 2011 | Cobra 29 LTD CB Radio
I have a whine in my dash that can be heard when the engine is reved. It feeds through to my CB radio when the radio is miked up
Interference may be caused by non - resistor spark plugs. If you don't want to change your plugs for resistor plugs, you may be able to get an inline resistor for the antennae from your local electronics supply store, like radio shack. Failing that, you can buy a cb antennae with a built in resistor coil that will also do the job. If you buy the new antennae, go to a cb shop to have your antennae tuned to your cb - it will increase your range and clean up your sound too.
Hope this helps, and please rate my solution!!
Nov 17, 2010 | GMC K1500 Cars & Trucks
How do I get back to regular CB channels on the 75-822? All I can get is 27.xx and 26.xx. Where are the 1-40 channels.
I'm guessing that you bought the CB from a person not a company the CB band is between 26Mhz and 27Mhz unfortunately your CB was Modded to talk on Ham radio frequency's what i would suggest is one of two things if you are good at electrical soldering get a schematic and take out the mod or look on-line for a ham radio store like ham radio outlet near you and see if they can un modd it.
if you bought it from a store return it or talk to midland to see if they can fix/reset it at http://www.midlandradio.com/Contact-Us
one other thing until the radio is fixed it is not FCC part 95 or 97 compliant and is therefor illegal to transmit with it
Sep 04, 2010 | Midland 75-822 40-Channels Handheld CB...
I have a 30 year old cb radio that my teenage son wants to hook up. Is there a way to hook it up in a house?
yes. go to any cb store and they will sell you the transformer and the antenna u need to make it work well. J.
Jun 03, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a cobra cb and it makes a weird sound all the time, when i accelerate the sound gets biger
What you are getting is ignition noise from the engine of your car. Could be spark plug noise or alternator whine. If your radio has a ANL or NB switch, turn it on. If that does not fix it, you may have to get a filter for your powerline or change where you are getting power for the radio. Hope this helps, with the limited info available. Let me know,,,Mechanic
Oct 09, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Midland 75-822 CB
http://www.midlandradio.com/comersus/store/catalog/75_822.pdf
Mar 16, 2008 | Midland 75-822 40-Channels Handheld CB...
CHANGING FROM FREQUENCY TO CHANNEL MIDLAND 75-822
Some models of the 75-822 do not offer this as a feature. Instructions for it are not included in the manual. I recently encountered a refurbished model packed with a manual such as this. Pressing and holding the "F" button toggles between Channel number and Frequency number display.
Jun 17, 2007 | Midland 75-822 40-Channels Handheld CB...
Motorola Mobility W385 Cellular Phone Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
