Question about Smeg FME24X Microwave Oven
My smeg microwave oven plate is not turning
The microwave is heating up but the plate is not turning. I have tried the button to reset the 'cancel turning' button but the plate is still not turning.
My Russell Hobbs microwave seems to be stuck on some kind of timer and I've tried everything to cancel it but it's not having any of it. When it's not actually cooking it seems to be in some get ready mode...
Put a glass of cold water in it as see if it heats up? All microwaves have a timer so that after cooking the internal fan stays on to remove cooking smells and condensation from the chamber. It should however turn off after about 5 minutes as long as the door is closed. The plate should only rotate when a time is set and the cook button is pressed.
Oct 18, 2017 | Russell Hobbs Microwave Ovens
My microwave GELX1800 is not heating... when the express button is pressed it opens the vent lid and the plate turns around but is not heating. The vent lid should not be open when the cooking buttons are...
Try a hard reset first: Unplug the oven or turn off its breaker for a minute or so, then set the clock & try it again.
If it still fails, did the cooktop lights go out recently?
It may need circuit board repair, which is usually economical.
Oct 27, 2013 | GE XL1800 1100 Watts Microwave Oven
My smeg microwave will not heat the food ...... possible causes
If everything else is working but it won't heat the food, the causes are the magnetron "common failure" or the high voltage capacitor and diode can be a factor, the three work together to heat the food. Depending on the nature of repair it can be close to the cost of a new microwave oven.
Feb 27, 2011 | Smeg FME24X Microwave Oven
Smeg sa35mx microwave vibration noise when in use
The vibration can be due to either the transformer which is getting loaded when the magnetron is ON or it can be the vibration of the turn table - possible fault in the drive mechanism or irregular movement. If this is the transformer check the voltage and if it is heating up then it can be faulty , if not the mountings of the transformer can be tightened.
Also the turntable movement drive can be reset.
Feb 05, 2011 | Smeg Microwave Ovens
Turntable does not spin
There is a coupler that connects the turntable motor to the plate. It's the square or odd shaped object in the center of the microwave after the turntable is removed. You can try to pull it up from the microwave to see if it is broken or if it will turn by hand, it is probably broken.
Jun 21, 2010 | Smeg FME24X Microwave Oven
Does not heat food.
Dont have many smegs where i am, but smeg is a decent unit, so i would think if there is no heat, look for a reset button (over temp. protection). possibly located at the back where the elements are wired.
Sep 15, 2009 | Microwave Ovens
Microwave doesn't heat, plate doesn't turn
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkfjfk
Jan 26, 2009 | Whirlpool MH3184XP Microwave Oven
Lost the manual
Smeg's user manual link: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Feb 25, 2007 | Smeg S43KIT3750EB Microwave Oven
Smeg FME24X Microwave Oven Logo
35 people viewed this question
Top Smeg Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
