Question about Western Digital WD500AAKS
NOT WOKING Western Digital WDBAAR5000ABK-PESN
    Brigadier General:
  • Western Digital Master
  • 3,400 Answers
DETAILS HOW SHOULD ANY ONE POSSIBLE HELP YOU WITH
OUT DETAILS.
Posted on Feb 17, 2014
Drive does not appear on macbook pro
You need either need a driver to detect the hard disk or you will have to format hd.
Jul 25, 2014 | Western Digital WD Elements Portable...
HDD WESTERN DIGITAL
Verify in BIOS first. It must be listed there.
May 03, 2013 | Western Digital WD500AAKS
My hard drive cannot initialize media write protected
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope it helps
Jul 10, 2012 | Western Digital WD Elements Portable...
My PS3 wont recognise my WD Elements 500GB hard drive
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 27, 2011 | Western Digital WD Elements Portable...
My western digital wd2500jd does not get detected
try detect it from BIOS
if its not detected mean your western digital wd2500jd controller is need to be replace.
try ebay to buy its replacement.
just seacrh with keyword "western digital wd2500jd mainboard"
Mar 07, 2011 | Western Digital Caviar SE WD2500JD...
WD Elements DCM BCCBAAA not working how to fixes this? plug in and no light comes on cant fin d removeble disc either
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 16, 2010 | Western Digital WD Elements Portable...
MOTOROLA W385 LOCK CODE
please visit this website<http://www.emobilez.com>
May 27, 2009 | Motorola Mobility W385 Cellular Phone
Western Digital WD500AAKS Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
