Question about Sport & Outdoor - Others
Our Coleman Spa will not operate as the GFI keeps tripping. This happened about 4 months ago and eventually we could reset the breaker. Does this appear to be a bad GFI breaker or do you suspect another issue?
3 Suggested Answers
Ostewart2102
  • 41 Answers
SOURCE: hot tub breaker keeps tripping
You are exatly right. It's really not that uncommon for Older models to have faulty motherboards. Once you replace that, it should be working new.
Posted on Oct 15, 2008
  • 8 Answers
SOURCE: Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
Posted on May 09, 2010
My hot tub works for about 20 mins and clicks the GFI off. Then I reset the GFI and the spa comes on for about 7 mns and trips the GFI again. Is this my heater doing this?
Easy way to test for the heater issue is to disconnect the heater from the board. Disconnect both leads from board and let the spa call for heat. There is also a chance the GFI breaker is bad however most times the heater fails and the breaker is doing its job.
Apr 01, 2017 | Hot Tub Works Pool & Spa
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Refrigerator keeps tripping the GFCI outlet. We replaced the outlet. Still have problem. It first happened several months ago (just once), but has happened several times during last few days.
GFI circuit breakers are weak when used with refrigerators and other appliances that use amperage especially during defrost. Replace with a normal 20 amp receptacle
Appliance 911 Appliance 911 Sea Breeze
Aug 01, 2015 | Refrigerators
Sta-rite heater is about a year old. It worked well up until a week ago. It now trips the gfi breaker. I swapped out the breaker and it trips that too. If I disconnect the exhaust fan, the heater powe
Something in the electrical system supplied by the GFI breaker has a ground fault. The current to ground required to trip a GFI is very little such that dampness on any electrical connection can trip it. This is especially true with motors that have a lot of fine wires in the windings and are open to allow cooling.
Hard water and pool chemicals all are worse than condensation from the air because of their ionic nature.
If the same GFI powers the pump it is what I would suspect first. Your question got cut off before the result of the fan disconnect which if disconnected didn't trip the GFI, is probably the problem. But you should open whatever you can access containing electrical components and make sure everything is dry
Feb 07, 2015 | Sta Rite Pool & Spa
Spa blower trips gfi
call an electrician to do an insulation check
insulation will eventually break down under ground normally from ants eating it
Mar 09, 2017 | Pool & Spa
Qo260gfi not tripping
Question is not fully clear.
2-pole 240Volt gfci circuit breaker requires the white wire be connected to neutral busbar.
Easy solution for 240Volt spa that comes with gfci:
Replace spa gfci with regular non-gfci breaker.
Install 2-pole GFCI breaker in main panel, and connect wire to spa breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
Having 2 breakers is not a problem.
Having 2 GFCI on same circuit is a problem.
Apr 18, 2013 | Pool & Spa
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
Home fuse box breaker issue
Hi Rex,
It sounds as if the upstairs bathroom outlet and the outdoor outlet are on the same circuit. There's a very good chance that these are GFI or "ground fault interrupter" type outlets, as these locations (and others) have required this type of protection for over 30 years. It was a common practice to run a circuit from the panel to one of these locations (or another) and then run from here to the next outlet and then on to the next. Since the GFI outlet could be purchased for around $10 instead of $30 for a GFI breaker, electricians would install outlets instead - both offered the same protection. A "regular" breaker would supply power to this circuit - but the very first outlet would get a GFI type outlet. It would be wired to the LINE terminals and the cable that feeds the rest of the outlets on this circuit would be connected to the LOAD terminals. If there was a ground fault condition, this GFI outlet would trip, but the circuit breaker would remain on. You would locate and RESET the tripped GFI outlet to restore power. The only time the circuit breaker would trip is if the circuit was overloaded. Overloads would NOT cause the GFI outlet to trip.
Now that you understand how it was typically wired years ago (and still a lot of times today), you should check all the outlets outside your home, in bathrooms, basements, garages, and inside your home next to doorways that lead directly to grade of your lawn or deck. These are required places for GFI protection. Press the RESET on any tripped GFI outlet to restore power. If the outlet will not RESET, there is a condition where the hot wire (black, red or blue insulated wire) is in contact with ground, or a device or appliance connected to the circuit has a problem. Unplug anything connected to the circuit and attempt to RESET again. If still unable to reset, open the outdoor outlet again and carefully pull it out and away from the box. Inspected for damaged or crushed insulation and repair / tape as needed. Before reinstalling, try to reset again. If it holds, trip the GFI by pressing TEST button. The RESET button should pop out. Reinstall the outlet and make sure the wires are not crushed or cut. Press the RESET button again. If it trips, you will have to remove the outlet again and take more precautions against damage to the insulation. it is also possible that the GFI outlet itself has failed, in which case it should be replaced.
GFI circuit breakers and outlets are supposed to be tested monthly by simply pressing the TEST button and then the RESET button. Replace any GFI device that does not test correctly if wiring and devices / appliances connected are OK.
I hope this helps & good luck! Please rate my reply - thanks.
Jan 05, 2012 | Hammering
May 08, 2010 | Pool & Spa
Sport & Outdoor - Others Logo
21 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
