Question about Pacific Image PrimeFilm 2700 Film Scanner
Primefilm 2700 windows 8 - Pacific Image PrimeFilm 2700 Film Scanner
I have a primefilm 2700 scanner and I'm looking for drivers for this scanner for windows 7, can you help out?
Scanners are often not supported when a new operating system comes along.
The simplest solution would be to run an old computer with the correct drivers for the scanner, I'm afraid. You can probably get an old computer for around £30.00, which is far cheaper than buying a new film scanner.
Jan 20, 2015 | Office Equipment & Supplies
Prime film scanner not working with windows 8
You will have to go to the manufacturer of the scanner and get the new driver for windows eight , if they wrote one for that model. www.pacificdigitalcorp.com
May 15, 2014 | Pacific Digital PrimeFilm 1800u Film...
Pacific Image PrimeFilm 1800u Film Scanner : is there a Windows 8 driver out there somewhere? Can anyone offer some help in finding it?
PrimeFilm 1800u will not work on Windows 8.
Here is the response I received from the company for the question:
Where can I get drivers for windows 8? Windows 7 drivers are not working on Windows 8.
Response:
Hello, This scanner will not be supported on windows 8, all of our USB 1.0 technology scanner will no longer be supported beyond Windows 7.
Wendy
Dec 19, 2012 | Pacific Image PrimeFilm 1800u Film Scanner...
Trying to download a driver for primefilm 1800u
The drivers it needs are in Windows\system32\drivers and include usbscan.sys and 2 others. I discovered that I had to run the device troubleshooter until it came across the single image scanner, I let it install drivers and then it worked with the primefilm software. That took hours, but the solution was to let Windows 7 64 bit do a troubleshoot on the hardware.
Dec 26, 2011 | Pacific Image PrimeFilm 1800u Film Scanner...
Prime film 1800i 35mm scanner lost software
Dear Brian white the next link you can find the drivers, http://www.primefilm.nl/main.html.
On the page make the choice drivers on the top of the page, then USB ondersteuning Windows 95, then PrimeFilm/, then PrimeFilm 1800I/, here you find a manual, then choice Windows/, then 98se_me_2k_xp_vista/ and here you have de drivers and the update.
On de next site I have found Firmware Update only I have no experience with it
http://www.scanace.com/download/drv_pf1800lab.htm
Nov 23, 2008 | Pacific Image PrimeFilm 1800i Flatbed...
VIsta compatibility
Check the manufacturer site! http://www.scanace.com/en/index.php The following link shows vista compatibe drivers http://www.scanace.com/download/drv_pf2700.htm if you have any problems or questions, post back! regards, babb
May 08, 2007 | Pacific Image PrimeFilm 2700 Film Scanner
Pacific Image PrimeFilm 2700 Film Scanner Logo
64 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Willem.
Willem.
Greg Cann
Greg Cann
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
