Question about Sanyo C3672R Outdoor Condenser Unit
Never shuts off
All of the pressures are good but the unit shuts off. Inside temp. Says that it is satisfied but unit keeps running. Elect. Bill really high
    Master:
  • 409 Answers
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Coral Springs
Posted on Dec 02, 2015
What causes the compressor to quit working?
Most likely the thermistor inside the compressor is shutting the unit off to keep it from burning out. No fridge should run for that long no matter how cold you want it to be inside. If all the door gaskets are sealing properly your most likely problem is the thermostat is bad and not sensing the temp, thus the unit keeps running.If your doors are not closing properly (alignment or gaskets) same issue will occur. Check alignment and gaskets using dollar bill. Close bill between door frame and gasket, pull bill out slowly should feel resistance, if not door is crooked or gasket needs adjournment or door gasket is bad.Do this on all doors all the way around to locate problem areas.
Aug 10, 2014 | Kenmore Refrigerators
Outside unit shuts off while inside unit keeps running, temp goes up
outside unit going out on safety overheating or thermostat satisfied
Sep 17, 2013 | Ruud Handle Air Conditioner
Carrier gas furnace does not cycle right.
Check out the flame sensor see if it is clean and check the connections .
May 21, 2017 | Carrier Heating & Cooling
DONT KNOW EXACTLY WHAT IS WRONG. OUR POWER BILL LAST YEAR WAS 211.00 AND KNOW WITH THISE BILL IS 678.00. IT IS H EATING AN 18X23 ROOM. THE SETTING FOR TEMP. IS ON 72 DEGREES. THIS THING HAS RUN OUR BILL UP...
Simple way to pay less bill with big comfort.
Tips for it: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat" Clean indoor and out door periodically ( Once in 4 months) Clean Air filter every fortnightly. Avoid frequent opening of the door where it's air conditioned. Avoid keep closing the doors even a/c is switch off. It helps to cool the room next times in short minutes. Use proper breaker, wiring for your air conditioner plug points. Make sure your elect meter is working properly.Check your Elect meter with 1000watts bulb for one hour. It should consume one unit only. Hope, it's helpful.
Jan 08, 2011 | Heating & Cooling
Humms when not running
Hi, something is for sure still energized after it is satisfied. I would think it would be on the control voltage side, like a contactor coil or relay. What I would recommend if you are able, is to go up top to the condenser and remove the cover. With the unit satisfied at the stat, listen to see if you can find the componant that is still getting power to it and you will know. If it is nothing above, my guess it would be in the controls on the indoor unit. More then likely, I would say you will find your problem part up top. Please keep me posted on this. Let me know what you find. Something is still getting power to it. With the unit satisfied, am I right to say the hum is not coming from the breaker its self? Just asking.
Sincerely,
Shastalaker7
May 17, 2010 | Coleman Mach III Air Conditioner
Air conditiner nevers shuts off is it suppose to when it gets to tempe or will blower keep running
Most Rooftop RV Ac's iv seen the fan does not shut off, However if yours is one that should shut off completly then It more then likely is either the T-stat, Fan relay, or in some cases there is a Control circuit board, Just depends on what is inside of the unit.
May also want to check and see if there is maby a contactor that may be stuck in the closed position and not opening when T-stat is satisfied. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 24, 2009 | Dometic Rooftop RV Air Conditioner
Carrier unit runs all the time, never shuts down and the fan in the house will not shut off ' the house isnt getting beloe 80 degrees inside, even though I have the thermostat set at 76, I turned the...
Ya need preventive maintenance preformed evaporator clean condenser cleaned and the blower wheel clean unit could be under charged have it tuned up and your electric bill wont surprise you leave it running like it is and you will have a very large bill
Jun 27, 2009 | Heating & Cooling
Outside air temp around 100 unit wasnt cooling good noticed evap coils dirty cleaned them cooled alittle better checked low side showed 90 lbs had friend reclaim to get it to 70 lbs 30 minutes later it...
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Jun 25, 2009 | Heating & Cooling
Sanyo C3672R Outdoor Condenser Unit Logo
48 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
