Question about Timex Jumbo T254W Clock Radio
Alarm won't go off
Alarm worked once - now it won't work at all. Don't know what happened. Worked fine the first time - second day - no alarm. Cost use 39.99. What a rip off. Any suggestions?
  • Gail Borneman
    Gail Borneman Feb 16, 2014
    It was a Model T715 Timex Clock Not a T254W
SOURCE: the alarm goes off
Had the same problem on my timex/acqua; after reading a couple suggestions on this site, I held down adjust button at same time as start/stop and it worked after a second or so. Try any 2 buttons at once, one suggestion did 3 at once.
Posted on Dec 16, 2007
Look here
http://assets.timex.com/instructions/w89Instr.pdf
Posted on Jan 28, 2008
SOURCE: New Battery but Alarm sound doesn't work
You will find an arrow head on the outside back of your watch where all the printing is. When you put this lid back on, this arrow needs to be aligned with a notch on the inside edge where the cover goes on. As you are looking at the watch from the back with the cover off this notch is in a northwesterly direction. If you doubt it then just hold the back on without popping it in all the way and hit your mode button to make sure that you hear the beeps again. If you do, then you've found the right spot.
Posted on Oct 24, 2009
  • 18 Answers
SOURCE: Alarm only works sometimes. What am I doing wrong.
get it checked out
Posted on Mar 05, 2010
  • 10 Answers
SOURCE: Setting the alarm day on timex model T786779J. I have set the time, but don't know how to set the day of the week. Can't change it from Tuesday.
from what i read sounds like you have to turn it twice to advance to the next day . Hope this helps
Posted on Dec 27, 2016
How do I fix this problem: The OK light flashes. The washing machine worked for an hour but then this problem happened.
Obviously, an alarm is displayed after some time.
The alarm is displayed by a repeated flashing sequence of the START / PAUSE button with yellow and red light (0,5 seconds on, 0,5 seconds off with a 2,5 second pause between the sequences).
• button indicator START / PAUSE with yellow light indicates the first digit of the alarm code (family)
• button indicator START / PAUSE with red light indicates the second digit of the alarm code (internal number of the family).
Dado
Jun 10, 2016 | Electrolux Washing Machines
92 Toyota 4runner truck was running perfectly fine Later in the day went to start and the alarm just started going off and wouldn't turn off. Truck won't start even with keys turned in igniti
The alarm system somehow got activated , this is usually because the battery becomes discharged or disconnected try doing this:
Remove the key from the ignition
disconnect the negative battery terminal
put the key back in and turn to ON
exit the truck and leave door open
reconnect the battery terminal
get in and leave door open, if the alarm horn stays off it should start.
Dec 07, 2012 | 1992 Toyota 4Runner
Car won't start and arms alarm when I turn the ignition
Dead battery armed the security system. Remove the battery cable let the system reset. Charge the battery. Use the key to unlock the door instead of the keyless entry. This resets the alarm once the battery is charged.
Nov 01, 2012 | Volkswagen Cars & Trucks
Removing hourly chime from a sportek watch
I know it's been a year since this question was asked, but I was trying to find the answer today and finally figured it out. I thought I would answer for someone else.
I have a sportek SP1020ZEL. Pressing mode first and then alarm did not work for me. Pressing mode first on my watch only put it into the stopwatch mode, and then pressing the alarm button is for reseting the stopwatch. So I tried it the other way around, and it worked.
First, press and HOLD the alarm button (bottom right button) and then the mode button (bottom left button). My sportek doesn't show a little bell symbol, but I noticed that with one press all the days of the week showed and when I pressed again all the days disappeared. So I waited for the hour and found that when there is no days of the week visible the hourly chime is off. I don't think this works with all sportek watches but it is worth a try. (I did not try holding all the buttons for 5 seconds).
Jun 17, 2011 | Watches
1998 v6 regular mustang the original factory installed alarm system activates by itself 1-3 times a day for no reason.Once the car key is put into door and opened the alarm will go off. Also, the interior...
this happened to us when we got a new key and had it programmed with the car. anytime we locked the doors and opened them with the key instead of the remote, the alarm would set itself off. we took out the fuse for the alarm.
Jun 14, 2011 | 1998 Ford Mustang
The alarm clock on S5230 soemtimes work and sometimes it doesnot work, please help
Here's how you do it:
Menu--Alarms--Tap to create--Alarm Name and Alarm Time [the time you want the alarm to go off] (I'm sure you can fill that up)--Now here is the part where you are facing the issue--The Alarm Repeat--Now press the Week days Tab--Select Everyday if you want the alarm to repeat everyday or select alternate days--Click Save.
Now the alarm will go off according to your set schedule.
If you need more help on that do let me know.
Feb 07, 2010 | Samsung SGH-S5230 Cell Phone
2007 VRSCDX Alarm system "key" icon is on while riding
Got a feeling guy installing xtra lites didn't do a good job grounding his new installation...if the alarm is working fine now then don't worry about the alarm....recheck his work and rig up an extra ground wire if need be....good luck to you friend.....tim
Apr 25, 2009 | 2008 Harley Davidson VRSCDX Night Rod...
Alarm does not go off when the off button is hit
Hello!!
try hard resetting once according to ur manual!!! and do let me know.. thanks you!!!
Jan 12, 2009 | Samsung Blackjack SGH-I607 Smartphone
1998 town n country alarm/ start problems
This may or may not help. Hopefully it will. We recently purchased this 1998 chrysler town & country. Everything was working fine, started fine, etc. we took it to get emissions done.....passed emissions.. .made it home. i turned the car off to run inside for a minute. came back out car started.. ran for 3 seconds than died out. tried again... ran for 3 seconds than died out... after that it no longer would do anything. all the lights worked except in the ignition module. the top dashboard lights worked though. I then noticed that the "alarm set" light stayed lit. after replacing fuses and running an OBD test and found no trouble codes or issues with fuses it dawned on me it may be the alarm. after searching the internet for hours i found a forum that suggested unplugging the battery for about 5 minutes....rehook it and then try starting it again. well i tried doing that the first time using the REMOTE to unlock the doors and nothing happened. i locked the doors and repeated the same battery unhook-rehook process except without using the remote... (i noticed a lot of forums saying that the remotes can be deffective in that they somehow trigger the alarm if the transmitter is not working properly)... so after unhooking and rehooking the battery and using only the key to unlock it started right up! so i've decided to not use the remote at all and have had no other problems. let me know if this helps
Oct 04, 2008 | 1998 Chrysler Town & Country
The alarm goes off like twice a day ,a lost the manual ,and i don't know how to stop the alarm to go off
Nov 08, 2007 | Timex 48021 Wrist Watch
Timex Jumbo T254W Clock Radio Logo
27 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
