Codice tv mivar cs1056 x2
I want to know the code of this type of remote control
SOURCE: Sky remote code for LG 42LC46 tv
Hi - I also have the LG42LC46, i got it to work by using code 206 but you need a REV 8 remote, i tried it with a REV 4 and it doesn't work.
Regs
Dee
P.s. let me know if it worked for you.
Posted on Mar 28, 2008
shawty-lozzy
  • 151 Answers
SOURCE: remote control code Akari IC1494P2?
what make is the remote? codes are different on other remotes
Posted on Jul 20, 2009
SOURCE: Direct TV Remote Control RC64 Code for Insignia TV
http://www.fixya.com/support/t1555766-direct_tv_remote_control_rc64_code this worked for me after doing a GOOGLE search. 10150 is the code that even worked for TV power. Here are the other codes supplied, in case link didn't work, 10463, 10054.
Good Luck!
Posted on Sep 02, 2009
  • 524 Answers
SOURCE: My TV remote comtrol will not work when I try. I need the code.
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
096,10,146
Thanx
Posted on Jul 28, 2010
gopakumarg43
  • 75283 Answers
SOURCE: uet-606 universal remote control code for comet tv
Just do a code search method. It will be best rather than try to get the code list to this remote control. If your remote control have pre-programmed codes for your device, this method will help you to synchronize it, and you can retrieve the code too. Procedingns are given.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Posted on Jun 24, 2012
Chunghop code L 208 serve codice prorammazzione tv LG
1849,1884,1882. Try these codes.For more information http://electrohelponline.blogspot.com/Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Dec 09, 2013 | Universal Remote Control Remote Control
I have a RCA tv and I have a LM-620 universal remote how do i make them work
salve avrei un problema con il telecomando da poco acquistato in quanto nella mia televisione autovox non funziona il codice quale codice devo mettere
grazie anticipatamente
Sep 10, 2012 | Philips Magnavox Learning Universal Remote
Codices del control Zenith zn401s
Write your answer...memorex tv
I need the code.
Feb 03, 2011 | Zenith ZN401 Remote Control
I lost my original remote control for my AIWA combination TV/ VCR. VX-S135 ? I bought a universal remote control but there was no code listed for an AIWA TV. Just a VCR. I need to know the code to the TV...
what's the name/make and model of the remote?
Without me knowing the type of universal remote, there is no way I can get the right code for your TV.
I look forward to your reply.
Bye for now.
Jun 24, 2010 | Aiwa Televison & Video
I lost remote control, wich universal remote can
Hi, I have the same problem as you.
Could you solve it?
Regards, Paka.
Dec 13, 2009 | Encore ENXTV TV Input
Televison & Video Logo
Top Televison & Video Experts
