Question about Panasonic NN-SF550M 1000 Watt Microwave Oven w/ 1 cu ft Capacity, 10 Power Levels, Popcorn Setting, Reheat, Inverter Turbo Defrost and Keep Warm Functions & Child Safety Lock
Door broken on panasonic NN-A723M
Door is cracked and I need a replacement
SOURCE: Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Posted on Apr 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-T687 (The Genius) door
You will need to remove the oven from the frame, then remove the outer cover from the door.
Once the outer cover's off, you'll be able to see that door opening button presses against the door opening lever, which presses up on the door key/hook to open the door.
Usually the problem is a broken door opening lever.
You can order that part directly from Panasonic here.
Once it's fixed, if you want to download the owner's manual, it's here.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: broken door latch on mod.nn-t945sfx
Do you mean the part with hook-like projections that stick out of the door, or the part that holds the door switches inside the oven?
If you need to replace the door latches (the hook-like devices in the door) you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can order Panasonic parts from Tritronics here or by calling 866-779-5835.
Posted on Dec 15, 2008
SOURCE: Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Posted on Jan 20, 2010
  • 421 Answers
SOURCE: panasonic nnt774sf door will not remain closed.
You can purchase parts for Panasonic microwaves but home repair is not recommended due to them being lethal if you do something wrong. I would find a good local repair shop and they should be able to find the part and repair. It might not however be cost effective, depends on the part price.
Posted on Mar 11, 2010
NN-SN778S DOOR LATCH SCHEMATIC DIADRAM
There should be tension from the spring that pulls the door hook down. If there is no tension, the anchor for the spring has broken off and the outer door frame must be replaced.
Sep 02, 2014 | Panasonic Microwave Ovens
Door will not open. Nothing broken in the mechanism
Hi Glen,
Have you taken the wrapper off of the unit to open the door? You usually have to use a pencil or small screwdriver to lift up on the bottom latch head (doorkey as Panasonic calls it). These counter top models typically use a three step method to open the door. The push to open button pushes on a lever that then lifts up on the bottom doorkey. The lifting lever cracks and won't support fully the weight of the doorkey. The crack can be small enough to not really be noticeable if you are not very familiar with this problem. I'm pretty sure that this is what you will find. Let me know..
Oct 21, 2013 | Panasonic NN-P794SF Microwave Oven
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
The door won't latch closed and the door release button pushes all the way in
I have the NN-T994 SFR model and it had a switch that was staying depressed. I removed the screws to (in my case) the stainless steel cabinet, removed the cabinet and unhooked the wires to lay it aside. Found that the switch was cracked or broken, glued it back exactly as it was, then put the cabinet back on and it fixed it! Now about a year later, I have another problem...oh well. Hope this works on yours.
Sep 28, 2009 | Panasonic NN-T990SA Microwave Oven
Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Sep 11, 2009 | Microwave Ovens
PANASONIC NN-S952WF FAN AND CAROSEL STILL CONTINUES WHEN DOOR IS OPENED. NOT SURE IF THE MICROWAVE CONTINUING AS WELL WHEN DOOR IS OPEN.
The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
May 13, 2009 | Panasonic NN-S952 Microwave Oven
Cracked door on Panasonic S753 combi microwave oven
Hi I have a Panasonic combi oven in between the glass door is misting up should I be worried
Jan 07, 2009 | Panasonic NN-S753 Microwave Oven
Oven door
It's probably not the spring.
It's probably a broken spring mounting tab on either the inside panel of the oven or the "door key", which is the part that has the hook like projections that go into the chassis behind the door.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can order Panasonic parts here: http://www.pasc.panasonic.com/epartr
(select Order Listing ByPart Number) when searching
Mar 14, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-SF550M 1000 Watt Microwave Oven w/ 1 cu ft Capacity, 10 Power Levels, Popcorn Setting, Reheat, Inverter Turbo Defrost and Keep Warm Functions & Child Safety Lock Logo
63 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
