Question about Behringer DDM4000 Digital Pro DJ Mixer with Sampler DDM-4000
My ddm4000 starts well but then flashing lights start and loss of control occurrs
The problem has arisen since nearly newfrequently but not constantly
  • 3 Answers
WHAT THE MIXER IS DOING A SELF TEST ON EVERYTHING
AFTER IT HAS DONE THAT PRESS THE CENTRE BUTTON ON THE MIXER AND FOLLOW INSTRUCTIONS.IT IS GONNA ASK TO PUSH BACK ALL THE BOTTONS
AFTER YOU DID THAT PUSH THE CENTRE BUTTON AGAIN AND FOLLOW INSTRUCTIONS. ITS GONNA ASK YOU TO EVERY SWITCH AND KNOBS AND SLIDERS. BUT YOU GONNA NEED A MIDI WIRE TO LOOP IT FROM IN AND OUT AFTER IT HAS DONE THE TEST YOU ARE GOOD TO GO.BUT YOU MUST REPLACE THE FUSE.THE REASON WHY IT DOES THAT WHEN YOU TURN IT ON THE FUSE IS NO GOOD.IT WILL TURN ON BUT NOT RUN A FULL SWING!
TURN OFF THE UNIT
ON CHANNEL ONE OF KILL BUTTONS HOLD DOWN ALL THREE WHILE TURNING THE UNIT ON
Posted on Mar 23, 2015
  • Behringer Master
  • 3,368 Answers
I am not familiar with your unit but it sounds like the extension cord is connected to both the lights and mixer, if so use two extension cords. I have seen a lot of horror problems with undersized extension cords.
Good Luck
Posted on Jul 01, 2014
How can I diagnose the problem with the indicator light flashing after supplying power for only a minute?
a problem has arisen in the converter panel /board
take it in for a proper diagnosis and repair
Apr 20, 2016 | Honda EB3000C CYCLOCONVERTER Generator -...
2004 sebring conv. shuts off after getting of normal operating temp. Will start again after it cools off.
Did you do the key "Dance" for codes? Put key in ignition, turn to the "RUN" position - do not crank the engine - and return it back to the off position, do this four times, on the fifth time leave it in the "RUN" position and watch the check engine/power loss light and count the flashes. Should start with five flashes (start of test) followed by a couple series of flashes keep track of the number of flashes as this will tell you what sensor is on the fritz. The test is over when it flashes five times again. Also the chain stores will scan for zero cost.....Just for grins try unplugging the water temp sensor (usually near the thremostat) see if car stays running......Plug it back in to double check.
Feb 28, 2014 | 2005 Chrysler Sebring Sedan
Ddm4000 flashing and crashing
It sounds like it got blasted with ESD, see if you can get it repaired under warrenty.
Feb 16, 2014 | Behringer DDM4000 Digital Pro DJ Mixer...
Mod.Hp980PT, red and top green light flash, no heat
This is a very common feature on these types of simple, high-volume, low-cost home appliances known as a safety fault. This fault will temporarily (or permanently) disable the appliance and happens for several reasons: (1) an over-temp (high heat) occurrence, (2) an over-power (power surge) occurrence, (3) an under-power (power outage or trickle power) occurrence, (4) an over-time occurrence (auto-off fails), (5) a short-circuit occurrence (exposed/crossed/frayed wires, etc.). Fortunately, it uses a digital "fuse" system and can be reset by the user. However, there is no universal reset process on SoftHeat products so you just have to play with it until you figure it out (customer service dept is no help). Mine is a Kaz SoftHeat HP980PT, with a red power indicator/power-off button and 4 green heat setting buttons. Mine faulted after a heavy storm caused multiple power outages and power surges in my neighborhood. The green light on the highest heat setting button was flashing on mine. Here's how I fixed it: (1) unplugged both ends of power cord and straightened out the cord, then plugged back in to the heating pad end. (2) While holding down the flashing light button, I plugged back in to the wall outlet. (3) While still holding down the flashing light button, pressed and held down the red power-off button, then while still holding down the red power button, I released the flashing light button, followed by releasing the power-off button. This stopped the flashing green light and caused the red power indicator light to stay on (steady-on). It works fine now. Note: Some models have an actual hard fuse in addition to the digital fault feature or possibly only a simple fuse (without the digital fault system). These fuses can the found at many retail stores and then very easily replaced. I hope this helps some of you!!!
Jan 27, 2014 | Softheat Heating Pad HP218 12 3P
I have a timing problem. Low idle speed that is intermitten and causes a stumble at starts. This problem also occurres during normal running RPM's. Missing electronic signal but intermitten?
Could be bad sensor whether crank sensor, sam sensor, idle air control sensor, bad ignition module, bad coil or even timing belt. if you have a service engine soon light/creck engine light it's more than likely a sensor. If no light, probably timing belt/fuel filter plugged/ or weak fuel pump.
Jan 17, 2013 | 1995 Toyota Camry
1986 dodge aries starts and dies after 2 minutes the lost of power light is on can somebody help please why is doin this? the pcm is stopping the fuel pump so the car dies i try sprying alcohol in the...
My Chilton book doesn't have a lot on vehicle specific emission controls. What I did find is this. Apparently the "loss if power light" will turn on if the temp sensor wire has been removed and then reattached. Have you recently done work at the thermostat? The temp sensor is mounted on the thermostat housing. To turn the "loss of power light" off, disconnect the positive battery terminal and then re-attach it. No waiting. Start the engine and then shut it off. After that turn the key ON and OFF several times to clear any fault codes in the computer. This may help because stored codes make the computer think the problem still exists and it reacts accordingly. Hope this helps.
Oct 07, 2011 | 1986 Dodge Aries 4 Door
My x-type diesel has been struggling for a few months running poorly and struggles to start (more so when warm). Jag told me the EGR and inlet manifold was coked up - which I have now cleaned. runs much...
COULD HAVE BAD FUEL WRONG TYPE FUEL COULD NEED NEW AIR FILTER. DIESEL ENGINE NEEDS AIR TO OPERATE.IF AIR FILTER RESTRICTED.DIESEL ENGINE WONT RUN AND CLOGGED FUEL FILTER CAUSE STARTING PROBLEMS PROBLEMS WITH TURBOCHARGER OR TURBOCHARGER ACTUATOR WOULD CAUSE ENGINE RUN VERY SLOW NO POWER ON TAKE OFF.I SAY PROBLEM IN FUEL SYSTEM OR AIR INTAKE SYSTEM.IF YOU HAD ANY OTHER PROBLEMS THE CHECK ENGINE LIGHT WILL FLASH ON.
Sep 19, 2011 | 2005 Jaguar X-Type
Power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer to clean and now wont turn on..No fan no nothing..Just a green...
If you didn't accidentally unplug the four pin connector near the CPU, you need to replace the power supply. This is actually a fairly common occurrence with the cheap ATX power supplies being tossed into systems these days.
Jun 15, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Oil light keeps flashing and dinging.
its either low oil pressure or oil change reminder check with vehicle manual as to what oil light coming on means will also tell how to reset if oil reminder
Oct 11, 2009 | 2000 Chrysler Grand Voyager
Behringer DDM4000 Digital Pro DJ Mixer with Sampler DDM-4000 Logo
658 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
