Question about Neff 24 in. S5443X2 Built-in Dishwasher
Electrolux dishwasher pump keeps running - Neff 24 in. S5443X2 Built-in Dishwasher
  • Fredrik Nilsson
    Fredrik Nilsson Feb 16, 2014
    Sorry. I'm totally new to this forum and tried to search for subject. I have an Electrolux ESF660 and the flooding pump keeps running. Anyone knows how to fix this. Saw that people having neff drained the pain dry, then cleaned up grabage down there. I'll see if I can manage that.
Ei24id30qs Electrolux dishwasher, drain pump won't shut off until it times out. tech manual refers to a level switch but schematic does not show it. Is it integral to the drain pump?
Not sure if this is same as my (older) dishwasher, but mine has a float switch ( a piece of styrofoam which triggers a microswitch) which sits in the bottom pan. As soon as any water accumulates here, the pump keeps running. I then get error code 30.
Nov 15, 2016 | Electrolux 24" Stainless Steel Built-In...
Electrolux dishwasher edw5505ess Lights are on motor humming, changed the float pump AND the water inlet module. Still does not work Still humming and light on though...
The motor is jammed and will burn out if you keep leaving it like that. Something could be jamming up the mechanism and causing your issue.
Nov 20, 2015 | Electrolux Dishwashers
We are having the error code 0 3 on are Electrolux dishwasher and on this forum I keep seeing check for suds in the tub but nobody ever says what that would mean or what to do about it.
Hey Kelly, I understand that you have received an error code"03" on your Electrolux Dishwasher. Typically "E03" indicates a possible short in the wash pump. This can sometimes be reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem is not corrected, consider contacting a professional service provider to assess the dishwasher completely. Hope this helps! -JK
Oct 06, 2015 | Electrolux Dishwashers
Electrolux 24 in. Diswasher
Hello Darlene, thank you for allowing me to assist you!
The "ER" code that keeps appearing on your Electrolux dishwasher stands for a Membrane Switch Failure. Normally that means that your control board has detected a stuck key or key pressed for more than a minute. That could possibly be an issue with your keypad or main control board. I would recommend having a technician come out to your home to properly diagnose and repair your dishwasher. I hope this is helpful. -Matt
Aug 02, 2014 | Electrolux EIDW5905JS Dishwasher
Electrolux 2430 dishwasher pump doesn't stop
Good Morning Friend,
I understand the pump does not switch off of your Electrolux 2430 dishwasher, and you are wondering how to clean the sensor yourself. Typically this is not a do it yourself job. This appears to be a UK Electrolux dishwasher. I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
WP
May 16, 2014 | Electrolux Dishwashers
Why does The pump runs continuously even with the door open?
Good Afternoon Martin,
I see that you are having trouble with the pump continuously running on your Electrolux dishwasher, model number ESL6114. From this model number, I am showing that this is a European model and questions would need to be directed to the manufacturer in that specific country. I could possibly find a number for you if I can kindly give me the country you live in or the country where your dishwasher was manufactured or purchased. Looking forward to hearing from you.
-Best Regards-
WP
May 08, 2014 | Electrolux 23 in. ESL6114 Built-in...
Aeg electrolux dishwasher wont wash just keeps beeping
well there are several possibility's. What was the washer doing? Rinse or cleaning? If there is standing water in the tub, then the pump went out or is clogged.
Dec 04, 2012 | Dishwashers
I have a frigidaire electrolux dishwasher that won't shut off after it runs through the cycle...can you help?
If it keeps running, it's likely a faulty thermostat, thinking that the water isn't hot enough. They're located underneath the dishwasher. Part number is 154290204
Jan 09, 2009 | Electrolux Frigidaire Professional Series...
Neff 24 in. S5443X2 Built-in Dishwasher Logo
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
