Question about A-Data Technology Adata USB C802 8GB BLK RETAIL AC8028GRBB Drive Case
8988285F - Intel - 1CE/Single Channel [TLC-8K]
Nnnnn
Posted on May 15, 2015
E8 Error
Hello here is the homepage:
http://www.asrock.com/mb/Intel/X58%20Extreme6/?cat=Manual
I think you have a ram problem:
1. Please install the memory module into the white slot (DDR3_A1,
DDR3_B1 or DDR3_C1) for the first priority.
2. Due to Intel CPU spec definition, the system will not boot if only
one DIMM is installed into DDR3_A2, DDR3_B2 or DDR3_C2 slot.
3. Due to Intel CPU spec definition, XMP DIMMs and DDR3 2000/
1866/1600 are supported for one DIMM per channel only.
4. You may install varying memory sizes in Channel A, Channel B and
Channel C. The system maps the total size of the lower-sized
channel for the dual-channel or triple-channel configuration. Any
excess memory from the higher-sized channel is then mapped for
single-channel operation.
5. It is not allowed to install a DDR or DDR2 memory module into
DDR3 slot; otherwise, this motherboard and DIMM may be
damaged.
Try only with one module, in the white slot.
Hope this will help you.
Jan 30, 2013 | Asrock X58 EXTREME6 LGA 1366 Intel X58...
I need to know how much main memory that supports my motherboard.
According to Intel:
(DIMM) sockets
• 800/667 MHz single or dual channel DDR2 SDRAM interface
• Support for up to 8 GB of system memory
Nov 10, 2012 | Intel Gateway E210882 Motherboard With...
Does the Biostar G41D3 Intel G41 Socket 775 Motherboard except a single 4gb memory module
Yes, with one you will not run in dual channel mode but, depending on what you are doing,may not notice any difference.
May 09, 2012 | Biostar G41D3 Intel G41 Socket 775...
Can i see all the information about n15235 with photos without any other words or error about the information I mean I just want to know all the details.Please kindly answer as soon as posible.
Hi, you can download a manual and drivers here:
But there is 2 different models of your mainboard.
http://www.foxconnsupport.com/download.aspx?models=en-us0000158&category=C000000001&series=en-us0000002&keywords=&sort=Drivers
Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
http://www.foxconnsupport.com/download.aspx?models=en-us0000191&category=C000000001&series=en-us0000002&keywords=&sort=Drivers
Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775) - 533/800MHz front side bus (FSB) - Single channel DDRII 533 / 400 x2 DIMMs - 1 x AGP 8x, 3 x PCI - ATA x 2 + Serial ATA x 2 w/ RAID - 5.1 channel Audio, AC'97 interface (Realtek) - 10/100M LAN (Realtek) - 8
Sep 16, 2011 | Foxconn (945G7MA-8KS2) Motherboard
Can you tell me what is the difference in performance without having Dual-Channel working as it should,compared to my present situation meening NO DUAL-CHANNEL working??
Dual channel means two channels of memory. there are two configurations you can use. you can use single channel method which has twoo ram sticks running on one channel or you can have a seperate channel for each ram stick. Dual channel is said to be the better way to run it because it increases speed of the ram. Now assuming you have 4 slots for ram. to use dual channel you have to run 2 sticks of the same value (MB) right next to each other. You cannot run 2 sticks of different values in dual channel mode. In the case that you do the sticks would pair together on a single channel. Hope this helps you better understand.
Mar 28, 2011 | Biostar TPower I45 LGA 775 Intel P45 ATX...
Can some one please let me know the name of the motherboard supporting Pentium 4 1.5 Ghz processor as well as Intel Core duo series of processors. Thanks, Ajay
The chips to which you refer are incompatible with respect to the socket used for each as well as the fact that Core duo and Pentium 4 1.5 GHz chips are from separate generations, the latter having been obsolescent since 2003. Therefore, there is no single motherboard that supports both, and the Pentium 4, Socket 478 boards can be obtained from various aftermarket sources.
Here is an example of the kind of board you need for your Pentium 4.
$11 to $290 from 21 sellers
ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc ps1.png?v=mmz7gze1hlc 3 reviews
ATA-100, Serial ATA-150, 0 MB / 4 GB (max), DDR SDRAM, Intel 865G, 4 x USB
Prepare for the future with the Intel Desktop Board D865GBF, a platform that is truly a generation ahead. This ATX board features next-generation processor, dual-channel DDR400 memory support, integrated Intel Extreme Graphics 2, an AGP 8X slot, 8 USB 2.0 ports, integrated 6-channel audio and next-generation storage device support.
FEATURES AND BENEFITS
Support for the Intel Pentium 4 processors featuring Hyper-Threading Technology and 800-MHz system bus in the mPGA478-pin package. Also supports the Intel Pentium 4 processors (1.60a, 1.80a, 2a, 2.20 GHz or higher) with 533-MHz or 400-MHz system bus in the mPGA478 package.
Intel 865G Chipset featuring Intel Extreme Graphics 2 using Dynamic Video Memory Technology (DVMT). Low-cost, high-performance graphics solution.
Dual-Channel DDR400 SDRAM support: Four DIMM sockets designed to support up to 4 GB of DDR400 SDRAM memory (also supports DDR333 and DDR266). Flexible support for either single- or dual-channel operation.
AGP 8X/4X graphics interface: Flexibility to upgrade via a high-end AGP graphics card.
SATA150 and Ultra ATA100 connectors: Flexible support of new-generation SATA150 (2 ports) and current generation ATA (2 channels) storage devices. « less
While the board for your Core Duo is widely available now
Mar 26, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Memory
No. It means that your system uses single channel memory rather than the dual channel DDR2 RAM. Hope this helps.
Jan 22, 2009 | Intel D102GGC2 Motherboard
A-Data Technology Adata USB C802 8GB BLK RETAIL  AC8028GRBB Drive Case Logo
948 people viewed this question
Top A-Data Technology Computers & Internet Experts
David Payne
David Payne
Are you an A-Data Technology Computer and Internet Expert? Answer questions, earn points and help others
