Question about Ipcw Ford F150 / F250 Ld 1999 2000 2001 2002 2003 Fog Lights Projector W/ Halo Clear-1 Pair
Heater was only working on high and then gave out
Heater was only working on high for about a week and then it finally gave out yesterday and now there is no air at all.
  • 3,187 Answers
You need to backflush your system, drain the system, drain the water out of the radiator plug is at the bottom of the radiator in engine bay, remove the radiator cap. when the water is out remove the water lines to the internal heater. you will find 2 pipes going into the fire wall to the cab, with and hose pipe and the heater controls on full heat flush the lines change pipes every now and then. when the water is clear coming out on both line, blow down one pipe this can some times move any hard or heavy parts left in the heater then flush out again on the line you blown down. then do the other pipe the same. now flush the engine, take the bottom hose and top hose of the radiator and flush the same way as befor you dont need to blow on this one just a good flush, now block the 2 hose's on the heater line dont connect the heater lines as you can force the muck in the engine back into the heater. then put hose in top pipe for the rad and the water should come out the bottom hose that would go to the bottom part on the radiator.when it runs clean you can now reconnect the pipes. when this is done you will need antifreeze or antifreeze summer coolant, now this can come pre done or no diluted, this is up to you or where you get it from, you need a 50/50% 50 water 50 antifreeze it is best to make it 55/45 for a full flushed engine as you will lose abit on getting the air out of the system. drained engine is 50/50. now put the antifreeze in the engine then the water 4 one liter bottles mixed other 1 full liter. then leave for 5 min. then add the water. you dont need to leave it for 5min but i do helps with bleeding air as the liquid is thicker than water at this point. then add the water slowly till it is at the top of the cap not the max past this. while filling squeeze a hose pipe. now you need to start the engine (no water cap on, heater on full with fan on 1 or off with just heat on) run engine and keep it at the level before starting engine after 3 min of engine running squeeze any and all pipe you can safely get to , don't put hands near to moving parts or fan as this can come on at any time. every now and then rev the engine 2000- 3000 rev is fine this will help get the air out. also check on the heat in the cab and the temp is rising good. when the engine get to temp and the fan kicks in to cool down the radiator turn off the engine and leave to cool down dont (DON'T) add any water at this point. when engine is cool top up to the max lin and put the cap on after your first run check pipes are fine and not leaking if any leaks it could be the pipe you put back on is not sitting right when engine is cool readjust it. heater should be working fine now.
Posted on Apr 04, 2014
2005 Jeep Wrangler Heater and Cigarette Lighters won't work
seriously I would be making a jumper wire to the battery for the blower .. power it directly..as long as you put a fuse in the line..and an on-off switch..
Jan 03, 2014 | 2005 Volkswagen Jetta
2003 KIA Sedona Last week the AC gave out - there was a hissing sound coming from the middle of the chasis on the passenger side. Yesterday after putting half a tank of gas in the car, I drove for...
Sounds like a catalytic converter problem. Driving through deep water can damage. See if you have exhaust flow at the tailpipe. The A/C is most likely low on Freon.
May 26, 2017 | 2003 Kia Sedona
Coils in my 2454 packed solid with ice. Thawed it out....worked fine for a couple of weeks. It quit staying cold so I dug behind the freezer to discover the coils again encased in ice. Thawed it...
your defrost heater around the coils is open and can no longer heat,or the adaptive defrost timer or defrost thermistor are defective located in the refrige control panel behind the temp controls and the thermistor is located on the defrost heater assy
May 02, 2010 | Maytag MSD2454G Side by Side Refrigerator
Heater wont heat
It sounds like the thermostat is loose and needs to be adjusted or replaced. Leave this to a professional if you don't know what you're doing. So many fires are caused by baseboard heaters.
Oct 01, 2009 | Honeywell HZ519 Baseboard Heater
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Fan Blower, Wipers, Window, coming off and on??
need heater blower resister that controls blower speed.
Jan 01, 2009 | 2002 Dodge Caravan
Replacing a Rinnai 403 FT
gday nelson. if you check out the specs on the rinnai range you will find another one that will go straight in. if you buy new it will come with a new flue kit. as far as recomended installation heights most of them are quite flexible. i installed a second hand 403ft yesterday with the centre of the flue at 140mm from the floor. recomended in the instructions were 240mm. a mate gave me the heater and i just had to buy a flue kit as the old one was already too short. if you messure your flue from inside and send me the specs i can give you a more difinitive answer.
Jun 09, 2008 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
DWF 61 wont end programme
After a number of visits by an engineer, who just guessed at what it could be, and then ordered a part, changed the part on another visit, I insisted that a 'senior Engineer' visit, and be allowed sufficient time to make sure the problem had been solved. The senior engineer visited a week ago, and finally diagnosed what I had been saying for six months, " The water heater is not getting hot". The senior engineer visited yesterday and changed the 'HEATER UNIT DWF61' part number MS-1801925 (UK). Just before he changed the heater unit he found an electrical connection disconnected, so it may have been the cause of the heater unit not working, although he changed the unit anyway. All working fine now, so will renew my maintenance policy.
Mar 02, 2008 | Hotpoint 24 in. DWF61 Built-in Dishwasher
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Ipcw Ford F150 / F250 Ld 1999 2000 2001 2002 2003 Fog Lights Projector W/ Halo Clear-1 Pair Logo
57 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Joel C.
Joel C.
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
