Question about Watches
How to disconnect the alarm on Baotian scooter bt49qt-9d?
The factory alarm was disabled by dealer, how do I put it back on?
Alarm off
- Keep on pressing mode button on watch till alarm mode appears.
- to verify alarm mode check out the time alarm rings and match it with the display while selecting the mode.
- press adjust button to disable
- or press two buttons on right of watch to adjust the alarm
Mar 29, 2014 | Casio G-Shock World Time Analog Digital...
I accidentally hid
To make the alarm appear press the button at 8 O'cloc.
To turn off/on the alarm press the button at 2 O'clock.
Jan 05, 2010 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Can't disable the alarm, the alarm goes off at 11pm every night and i want to disable it so that it no longer chimes at that hour. what do i do?
Press lower left hand button until you reach alarms may say snz or sig use the bottom right hand button to cycle through the options, to turn an alarm on or off press the adjust button top left you will then see off or on in the lower circle on the watch face. Also there is a graphical display at the top of the screen Alm sig and snz when there is no black bar here all alarms are off.
Dec 21, 2009 | Casio G-Shock G701D-2AV Wrist Watch
I need instructions on setting the alarm for the Pulsar Chronograph 100M. I'm able to set everything else. Your response is greatly appreciated. THANKS!!
I answered this for different Fossil watch post, but I believe it will be the same for your watch.
I'll re-post the answer below.
To set the alarm on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#0), FIRST CLICK (#1) & SECOND CLICK (#2).
The small dials located at the bottom of the watch face (6 O'clock) are the alarm minute and hour dials.
First, pull the crown out to the second 'click' (position #2) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #2!)
Second, set the correct time. (plus one or two minutes... time to complete this.)
Third, with the crown still out to position #2, push button "B" (bottom) until the alarm minute and hour hands are set to the present time (same as the large dials).
Fourth, push the crown all the way in- to position #0.
The current time on the large dial should read the same as the small alarm 'time'. {This is the CURRENT TIME, not the alarm SOUND SET.}
To set the alarm SOUND time, pull the crown out to the first click (position #1).
Push button "B" until the dials of the alarm are at the time you want the alarm to sound... It can only be set within 12 hours! ... It does NOT know "am or pm".
When the desired time is set for the "alarm sound", push the crown all the way in (position #0).
The alarm dials will now indicate the time for your alarm to sound, NOT the current time. (this way, you know that the alarm is engaged.)
To reset the alarm- or disable it, pull the crown out to the first click (position #1) and hold button "B" down until the dials advance and stop at the current time... it will stop at the current time- then release button "B". --- Push the crown back in (position #0) and the alarm will now be disabled.
If the alarm dials are always moving and at the current time, you know that the alarm is disabled.
If the alarm dials are stationary and not moving with the time, you know that the alarm is engaged and set to the time shown.
I hope this helps.
Nov 05, 2009 | Pulsar Chronograph Watch
Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Aug 30, 2009 | Timex 1440 Nylon watch
How do you turn off the alarm
What you need to do is hit "Mode" until you're in alarm mode, then hit start until all you see is :00, then if you hit adjust it'll disable the hourly beep. To disable the alarms press the start button until the alarm you want to disable (Will appear on the screen above the mode button) then press but don't hold adjust, the AL1 -5 should disappear from above the mode button now.
Jun 02, 2009 | Casio F91W-1 Wrist Watch
Remove alarm schedule
go to each alarm and press the upper button on the left side to disable the alarm
Feb 26, 2009 | Casio E-Databank EDB6101C Wrist Watch
WR30 Wristwatch
hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
1 time takes of the chime-hourly beep
2 times takes off the alarm tha you set
3x's puts the chime back and 4x's puts the alarm back on.
Jul 21, 2008 | Timex 1440 53591 Sports Quotient...
Watches Logo
46 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
