Question about Fuji Photography
Repair fuji gsw690
Shutter problem.
Ihave a sticky shutter release on my Fuji S7000 camara. How do i get to it to clean / replace the shutter release button
Take it to an authorized dealer/repair center is my best suggestion, and when you get it back take care to keep it clean, out of the grit and dust of life.
Apr 24, 2010 | Fuji FinePix S7000 Digital Camera
Fuji FinePix F30 shutter problem: won't take pictures
Its fairly easily fixed and its a common problem with the F30. The shutter button contact slides off upon impact when dropped, it must be re-aligned so that it makes proper contact and performs normally. All that is needed is the special screw driver for the F30 (easily purchased online, just google it: "screw driver for fuji f30" ) or bring it to your local watch/jewelry repair store and tell them to open it up for you.
We have two F30's and they both have been dropped, both did the same thing with the shutter button. But both were easily fixed. Always keep the camera in a safe place and away from kids, they are very sensitive devices. Use the wrist cord when taking photos.
Nov 19, 2009 | Fuji FinePix F30 Digital Camera
My Fuji Finepix F30 has a broken shutter button. The problem seems mechanical, because it won't work in any mode. Can it be repaired?
Nov 03, 2009 | Fuji FinePix F30 Digital Camera
The shutter-button on my Fujica ST 605N has losened.
Well, first - your Fuji is a 120 not 35mm camera and second, it is a range finder not SLR. But other than that, there maybe a shutter release lock on your release button that is worn. I'd say take it to a repair shop. These are the kinds of cameras that repairman can still fix. And it is well worth fixing properly. Good luck.
Oct 23, 2009 | Fuji GA645Zi 35mm SLR Camera
How do I clean the shutter?
To clean and inspect the shutter mechanism on a Fuji E900 camera involves stripping the lens down almost completely to get at the shutter. It is not a task for anyone to "have a go" unless you have already upgraded to another model. You will need to have a few tools to hand - 12 watt soldering iron, tri-wing screwdriver, small phillips or cross head screw driver, needle point tweezers and another camera to photograph each stage for reassembly. I have photographs of a stripped E900 which maybe of help to you. My email should be listed somewhere in my profile or on my tips n tricks for digital cameras under "THE ONLY WAY I KNOW HOW.." and was posted under Fuji's A345 but does cover most Fuji compacts. There are some parts to the lens which are not accessable due to the way it was manufactured and will break if you try to access but the shutter is accessable for cleaning.
Jul 04, 2009 | Fuji FinePix E900 Zoom Digital Camera
Shutter opening problem
How hard did you press on the button? it will focus if not all the way. Also, check your battery. Other than that, I don't know.
Apr 08, 2008 | Fuji FinePix F11 Digital Camera
Fujifilm finepix a350
This is a common problem with this camera and it needs to be sent back to Fuji for repair.I've been through it three times and then they replaced the A350 with an A400 and now I'm having the same problems with the A400.
They want to swap it with a E500.
Both of these replacements are less of a camera then the A350.
If they won't repair it under warranty I suggest you stay away from Fuji cameras in the future,I know I will never buy one again
Dec 14, 2007 | Fuji FinePix A350 Digital Camera
Repair Fuji F30 shutter button does not work, case damaged
I also dropped my Fuji F30.
The half-press of the shutter didn't work anymore.
I bought a triwing / triblade screwdriver (about 5 euros) to open the case.
The flatcable running from the knobs on top of the F30 to the main print was a bit loose. After reconnecting it, the shutter button was fully functional again.
It seems that from the backside the most 3 three wires in the flatcable are for the shutter, so if your cable is also a bit loose, this might solve the problem.
NB Remember to only open the backside of the casing, there is no need to open the lens-side. Opening and closing the backside is really easy and could be done by anyone with the right tools. (read screwdrivers...)
Oct 28, 2007 | Fuji FinePix F30 Digital Camera
Camera shutter button does not work
the only repair center in florida wants $106.00 just to look at it. any bewtter solutions for a camera I can buy NEW for $180.00??
john
904 334 5730
Oct 25, 2007 | Fuji FinePix F30 Digital Camera
Wierd pictures
This is caused by a shutter that is stuck open. Normally the shutter closes right at the moment that you snap the picture and allows the image sensor to record what it saw at that moment. When the shutter does not close as intended the image sensor cannot properly record the image. This is why here are the lines across your images. The shutter can stick either due to an impact knocking the delicate blades off their tracks, or due to dust or moisture contamination sticking them open or closed. If gently tapping does not free them; the camera will require professional repair. David Millier Advance Camera Repair
Feb 15, 2007 | Fuji FinePix A330 Digital Camera
Photography Logo
Top Fuji Photography Experts
TC CAMERA REPAIR.Com...
pontelemon
pontelemon
Jax Planet
Jax Planet
Are you a Fuji Photography Expert? Answer questions, earn points and help others
