Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
Noisy pump the pump is making a louder noise than usual
Whining noise on Volvo 240 when in neural and park
A common cause of a whining or buzzing type noise when not in gear (neutral and park) is a WORN PUMP in the transmission. How many miles are on the car??
A noisy pump is just noisy and won't cause a breakdown until it becomes MUCH louder. If the noise is not that loud at this point, just keep driving it for now, and chalk it up to normal wear & tear. But DOOO make sure your transmission fluid is topped off. The amount of fluid between the LOW and FULL marks is about one pint. DON'T overfill OR allow it to get below the LOW mark. Transmissions are VERY fluid-level-sensitive.
Sep 18, 2016 | 1988 Volvo 240
My car has a timing chain, when I start my car in the morning its very noisy then it quite down a bit,
noisy on start up is hydraulic lifter problem as they are loose until the oil pressure builds up. the adjustment is taken up and the noise goes
it mat have some noise from the chain until the oil pressure builds up as it has a hydraulic chain tensioner
you list it as a 2016 model and the only suggestion I could make is to go up a grade in oil viscosity
AS it is new the oil is probably 15w where I would use a 20 w 40 oil
run your engine against other new engines and see if the engine noise is louder ( use a noise meter ) and make the dealer do something as nothing gets quieter as it wears out --just louder
May 15, 2016 | 2016 Hyundai Elantra GT
When maytag washer is draining it makes noises . What could be wrong
You could have a bad pump bearing. something caught in the pump or broken impeller blades on the pump. Bearing noise or a bad impeller would be noisy for as long as the pump is running. Please be more specific if you can on what types of noise it is making, whether it is noise that was there before and is just getting louder, and whether or not the noise is constant or intermittent.
Dec 04, 2014 | Maytag Washing Machines
My '06 Honda Odyssey has gotten noisy recently.
If it is filled up to the "full hot" mark then you are okay, fluid wise. It almost sounds like once it gets warmed up, it starts running better. The "growling" noise (especially when turning) could be from it not getting enough fluid. Other than that, your power steering pump maybe on its last legs, and it is taking time to warm up before it starts pumping fluid correctly. Just make sure that you power steering resevoir is completely filled to the proper mark.
Aug 10, 2013 | Cars & Trucks
My car is making a noise when I back up. Sounds like a pump kicking in.
The noise your hearing is the rear dif. The oil in the rear dif get old and dirty and needs replacing if its noisy you'll need to flush the rear dif. If you go to a Honda dealer and ask them for a d.p.f flush they will know what it means and it only takes aprox half hour to an hour.
Mar 22, 2013 | 2005 Honda CR-V
Hi, Thee dryer makes a loud noise during cycle. It starts low, but it seems after each rotation it get louder. Has anyone ever experienced this and are there any solutions. Thanks for any assistance.
Describe the noise. If its a rattling banging noise you could have a broken exhaust fan which is usually attached to the motor, a broken cylinder roller (if your dryer has them) or worn felts. Maybe a noisy pulley. If its more a high pitched squeek it could be your motor or the parts just mentioned. A metal scraping noise could be something like a bra wire caught by the cylinder but I don't see how that can get louder as the rotates. Make sure the belt isn't cracked all over. Worst case scenario is that your motor is on its way out...
Good luck
Aug 29, 2010 | Dryers
Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
Apr 21, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pump noise is louder....
The problem is defintely the pump.
Afetr a number of years the pump components start to wear out. Some parts disintergrate and float around in the pump assemby causing the pump to be noisy. Because of the nature of the faut - the onset of noise is sudden.
If you are a handy man, pull the pump apart. Clean out the ruined parts and see if you can make a new part to replace the old one. Whatever you do, don't make the mistake that I made the first time - don't make a part out of ANYTHING that the dishwasher detergent will dissolve or corrode - like mild steel for instance. Use stainless steel if you have to make a part. A good source of stainless-steel is an old pair of kitchen tongs. These are made of SS and are thin enough to cut with WISS Snips, can be drilled and shaped and still retain strength to do the job.
Use some imagination and you will solve the problem. Dishwashers do not involve any high tech. It's just a matter of replacing what wears out.
Jan 16, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Fisher and paykel dryer works but very noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
77 people viewed this question
Top Grundfos Garden Experts
john h
rhill2901
Level 1 Expert
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
