Question about Toshiba 36HFX72 36" TV
TV picture is dark
Our Toshiba TV model 36HFX72 picture contrast is dark for TV and Video.  Is it time to get a new TV?
  • smithcon Feb 08, 2008
    I have the same TV, and the brightness has been fading for some time, so we have compensated by adjusting the brightness setting up higher and higher. We have the brightness setting now cranked up to 100 (the highest setting) just to make it look almost normal.
    The TV is only four and a half years old and gets relatively light use (less than one hour per day). Very disappointing.
    Does anyone have a solution for this issue that is homeowner-fixable?
The unit flyback has 2 adustments most likly one is focus the othercontrol on the unit g2 which if slightly adjusted will bump ur brightness up
Posted on Jul 30, 2008
We recently adopted a Akai TV model PT50DL24 and the sound and the picture is fine but very very dark. I tried adjusting contrast, colour,and brightness but remains a very dark picture. Please help!!
Tv have a word "LAMP" on it front face frame bazel?Yes,than this tv model have a projection lamp it is dying requirement of the projection lamp replacement.Tv can be save.Not no "LAMP" word on it the front bazel frame.Not repairable,because it is using CRTS-tv tubes tech.Sorry it is garbage tv time,those CRTS tubes are dying,not worth replacing and cost almost the same as a new tv itself,if u can buy it refurbish CRTS tubes anymore all.
Jun 07, 2011 | Akai PT50DL24 Television
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
I have no picture on my 15" LCD Insignia TV. My
You may have a burnt out blacklight... You can fix it easy by having the tv on while it’s a bright picture than quickly unplugging it... or it would be best to get a new TV.
Oct 27, 2017 | Insignia 15 in. Flat Panel LCD HDTV
How to change resolution on a Toshiba LCD TV from 480i to better?
Can't solve this problem, because I have the same one! I can say that adjusting some of the fine picture contrrols, like brightness, contrast, color etc help a little. This TV is supposed to go 720 and as high as 1080 I thought?..........
Mar 02, 2010 | Toshiba 32HL67 32 in. LCD Television
Toshiba television is black picture
If this just happens while vcr is playing. Check the vcr. Did you happen to adjust its brightness and contrast settings. If things doesn't change. Then if this model is a crt type could be adjustment on its flyback transformer is needed tweaking slowly its screen knob or tweaking also its focus knob until you got it to the level of viewing it correctly.
But be aware, hazardous voltages inside it. Or let th technician set it for you, its a minor adjustment.
Jan 09, 2009 | Toshiba 36AF41 36" TV
How do I fix contrast and brightness on 36" toshiba tv?
you can bring more brightness by removing cover on your tv and then you will see ther 2 button ther in back of your tv one is FoCUs and other is G2 rotate the G2 button till you see more brightness on your screen put the cover back and that is if you dont know to do that go to one authorised service
Dec 10, 2008 | Toshiba 36AF41 36" TV
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Picture too dark
Capacitors on the Ysus is bad. Buy a new Ysus board or change the 14 components on it from a repair kit
Feb 27, 2008 | Televison & Video
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Toshiba 36HFX72 36" TV Logo
137 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
