Question about Gateway GT5656 Desktop PC
5beeps then pause 5beeps - Gateway GT5656 Desktop PC
  • 4 Answers
This appears to be a media read error. Are you able to get into the BIOS before the beeping starts? You might have a dead battery which will cause a loss of configuration. If it defaults, it could be trying to read a CD that isn't present or similar.
Posted on Feb 16, 2014
Dell Insporon - 5beeps, 5times
Your Operating system is hanging. You need a system disc or repair disc to work around this problem. If you boot from a system disc or repair disc you can get to the recovery console where you can type the following command: chkdsk /r
Check disk will run well over an hour and you will notice the percentage of completion going from high to low, but that's ok. Let it run to completion then reboot. If it's not solved you will have to do a repair install of the operating system.. A repair install will not delete your data, documents, music, pictures, videos or programs.
Mar 20, 2012 | Dell Inspiron 1464 Notebook
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
It beeps 1 long then 5beeps. but noting turn on
According to the dell website
http://support.dell.com/support/edocs/systems/op740/en/UG/trouble.htm#wp1120374
that is the error code for no memory.
You should attempt to uninstall and then reinstall your RAM by disconnecting the computer from the power outlet, opening the case, locating your RAM modules and then removing them for about a minute. Then put them back in and try to start your computer.
I hope this helps! If not, comment back and let us know!
Dec 19, 2010 | Dell OptiPlex 210L PC Desktop
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Dec 25, 2009 | Televison & Video
1 beep 5beeps 1beep 1beep
Try remove the ram and clean the part and put it back ,.
Dec 02, 2009 | Intel Server Board SDS2 Motherboard
Constantly getting pause,pause.pause
if your pointer on video screen when you press button then it pause the video click on simple play button and check your mouse pointer or download opera browser kkkkkkkkkkkkkkkkkk
Nov 04, 2009 | YouTube Videos
How can I enter a soft (2 sec.) pause in a contact number on A766
1) From the Home screen, go to Start > Contacts
2) Select the desired phone number
3) Press the Menu soft key and select Edit.
4) Use the Left or Right navigation key to place the cursor at the place where the pause needs to be added.
5) Press the Menu soft key and select Insert Pause to add a two-second pause. The letter ‘p‘ will appear where the pause has been set.
6) Use the keypad to enter any additional numbers if desired.
Tip: You can create pauses longer than two seconds by entering multiple pauses.
Aug 01, 2009 | Samsung Propel A767 Cell Phone
Permanent pause
It might be that the memory chip is fryed and it thinks that you are hitting the pause button, or eather it is that something is caught in the pause button. Take it a part or find something that will fit in between the pause button and clean it.
Jul 14, 2006 | SanDisk Sansa m230 MP3 Player
Gateway GT5656 Desktop PC Logo
32 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
