Question about Karcher Garden
Karcher k1 keeps cutting out then won't start again
Runs normal then when you stop it won't come back on
4 Suggested Answers
  • 56 Answers
SOURCE: Hi.
Sounds like the thermal protection is tripping. If the motor has a problem or is running with to high of Amps it will heat up and cause this problem.
Posted on Jan 14, 2010
  • 56 Answers
SOURCE: karcher g2500vh..sheared off spill valve
I've seen that before many times. If you have removed all the broken parts you can purchace a new spill valve, grease it and install it. If not, you need to remove the pump and sit it brass side up before removing the bolts holding the brass to the aluminum part (you have to do it that way so the oil doesn't spill out. CAUTION: there is some spring tension on the brass head.), find the other pieces of the spill valve, then put it back together. Then you can buy a new spill valve and install it. there are several on-line companys that sell spill valves for karcher machines, but most of then you would need to call to get the part number and price. I'll help you out by giving you the part number.
Part #4.591-040.0
If this helped please rate it.
Bill
Posted on Jan 22, 2010
Testimonial: "Thanks Bill, It is disappointing that this has occured "many times". That indicates poor design, manufacture,etc. I'll install a new valve."
  • 10865 Answers
SOURCE: im having a problem keeping the motor running. it
Hello. Your carburator is gummed up. Get a can of seafoam fuel additive at the auto parts store and put the recommended amount into the gas. This will clear up the problem in just a few minutes. Joe
Posted on Mar 16, 2010
What shall I do my car running normally but suddenly the engine stop running and never start again.
need more info, year,make,model, is the engine light on have you retrieved all engine codes, when turning engine over, is it spinning very freely or just like it always did,
RE POST with all this info. to get a better diagnoses
Problem 5 Engine Cranks But won Start
http://www.linnbenton.edu/auto/perform/no_start.html
Engine cranks but won start
Feb 05, 2016 | Cars & Trucks
Thermador CVS36R Cook'n'vent vent won't go down and fan stopped workin
You probably will find that the vent is clogged with grease. A switch device works with the vent so the fan operates only when the vent is open and does not operate when the vent is closed. Things should get back to normal after a thorough cleaning unless the fan is defective and won't operate at all.
Sep 03, 2012 | Thermador CVS236 36" Cook 'n' Vent System...
Honda em5000sx generator won't start
I have a EM5000SX. My problem is my generator will not start unless I turn the fuel selector to off. Then crank it until it does start, turn the fuel back on. Run's normal . I run this generator for my cabin every weekend.
Aug 25, 2012 | Honda Electrical Supplies
My refirgerator model number pbf2255hew stop cooling & compressor stop working...tries to come on but won't
Check your fan on the back of refrigerator...Might need replacing..Surly needs cleaning
Dec 08, 2017 | Maytag Refrigerators
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
The car runs for a few seconds and then stops. Then it won't start at all.
Normally when a GM runs for 5 seconds or less and then dies, it can be traced back to a failing Anti Theft Security system. This is very common on GM vehicles. Read this link and compare your symptoms to the ones listed. Also look for a light on the dash that says SECURITY when it wont start. If you see this light, then you KNOW that this is the problem.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 30, 2011 | Pontiac Grand Am Cars & Trucks
I recently bought a Suzuki gs 550 and need to reduce idle speed i don't know how to do this at the carb
the idle adjustment screw is located between the number 2 and 3 carburator float bowls bottom rear. I can bairly get my hand on it, but found that a flat blade screwdriver works fine for making ajustments. backing out the screw lowers the idle speed, while running it in increases it. To adjust make sure the motor is warmed up and the choke is off. Make adjustments from the right side (looking at bike from the back), by pushing with the screwdriver on the knurals of the adjustment knob, pushing knurals up backs the screw out, conversly down runs it in. Try for around 1000 rpms for your set speed. You want it to idle smooth and low, but you want it set so it won't die out when you come to a stop when you are riding. If you can not get the idle in this range, then there is some other problem needing attention. However, the idle at times may run a little bit higher than normal when you come to a stop after a hard ride, and should return to normal set speed after it cools down some. You should also make sure that the throttle cable is set at the proper tenion, if too tight, you won't be able to lower the idle. you may have to make adjustments a few times to get it right.
Jun 12, 2011 | 1980 Suzuki Gs 550 L
My xbox360 just stop preading everything it runs and works just won,t play any games.
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
As long as the heat stops getting to the drive you will be fine.
Feb 24, 2010 | Microsoft Xbox 360 Console
Garden Logo
27 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
