Question about Refrigerators
Efi troubleshooting won't start. EfI fuse keeps blowing fuse
  • 1861 Answers
SOURCE: 1990 toyota pickup 3.0 v6,engine
This is an unfortunatly common problem with this vehicle, if my hypothesis is correct. Try this: disconnect the wiring connector going to the fuel tank, under the bed. Replace the fuse and crank the engine. If the fuse does not blow, then the power wire going to the fuel tank sending unit is shorted out to ground. I change about 15-20 fuel sending units a year for this exact same issue. Replace the fuel tank sending unit if the fuse does not blow. When you get it out, you will see the cause of the short, rust at the connection on top of the sending unit. Hope this helps.
Posted on Sep 15, 2008
  • 6 Answers
SOURCE: keeps blowing 15a efi fuse 1991 toyota pickup 2.2 re
there's a short somewhere causing that amperage to go up
Posted on Dec 13, 2008
SOURCE: I keep blowing EFI fuses on my Toyota pickup v6 4WD.
i have had this same problem.. check the exhaust pipe near the middle of the truck.. the o2 sensor was hanging down and would blow the efi fuse when the exhaust got hot.. took me months to find it..lol
Posted on Jun 23, 2009
  • 16 Answers
SOURCE: EFI fuse Keeps Blowing
I had the same problem at one point. My issue was a bad grounding point from the battery to the chassis. I would say check all of your grounding points.
Posted on Nov 10, 2009
  • 496 Answers
SOURCE: my 1991 toyota 4runner keeps blowing the efi fuse
Check the EFI main relay, the circuit opening relay, and the fuel pump relay. Inside the fuel pump relay there is a switch controlled by a coil. During start, the fuel pump gets full power for a couple of seconds to build up pressure. Once pressure is good, the fuel pump relay is supposed to switch (via the coil) the fuel pump to reduced power. If the coil in the relay is bad, the reduced power setting is not available and the fuel pump will run at full power all the time. At this heavy current draw, it won't be long until the EFI fuse blows. This would also give more pressure than is necessary to the cold start fuel injector which runs on a timer. This extra pressure during the time that the cold start injector is operating may be the reason the engine is flooding with fuel.
Posted on Jan 29, 2011
EFI 15 A fuse keeps blowing
check for a dead short in starter relay , wiring etc after the fuse
Jul 17, 2016 | 1998 Toyota Sienna
88 toyota pick up v6 keeps blowing efi fuse
you may have a short of some kind, when a fuse blows repeatedly it is no good just replacing, you are being told that something is wrong with the equipment.
You will almost certainly have to visit a technician for a diagnosis. It is unlikely to be something that an inexperienced end user can sort out I am afraid.
GOOD LUCK
Oct 26, 2015 | 1988 Toyota Pickup
15amp efi fuse blows
It is not related to car being cool down , I think you are having ignition switch on . The EFI fuse goes directly to the contact switchin the EFI relay. Maybe try removing the EFI relay, turn the ignition to ON, and see if the fuse blows.
Doing this, the car won't start, but it might give you a clue as to where the short circuit is located. ... Check the fuse/relay box next to the driver side fender in the engine compartment.
Apr 03, 2015 | 2003 Pontiac Vibe
Efi fuse keeps blowing. After I insert a new fuse the engine starts and I'm able to drive until it blows again seconds later
there is a short in a unit or wire that the EFI unit runs. It may even be in the EFI unit itself. Insert a new fuse and run the fault codes to determine if a fault has been recorded.
Aug 09, 2014 | Cars & Trucks
Why does my efi fuse keeps popping 1999 chevy prizm
Pull the EFI relay, replace the fuse, and see if it blows when you turn the key on. If it does not turn the key off, reinstall the EFI relay and remove the circuit opening relay/fuel pump relay. Turn the key on. If the fuse blows than we know the problem is One of the O2 sensors, the IAC, the purge solenoid, or the ECM You can unplug the O2 sensors, iac, and purge solenoid. Replace the fuse, turn the key on, and plug them in one at a time until the fuse blows. Replace that component. If the fuse blows with those unplugged than its probaly the wiring and possibly the ECM. let me know what you find and I'll help you more if needed.
Aug 05, 2012 | 1999 Chevrolet Prizm
I have a problem with a fuse to EFI toyota corolla 2003
Hi there:
Sounds like to have a fuel pump that is shorted out or has too much resistance, this can cause to much of a current draw and blow the fuse. The EFI fuse supplies voltage to the EFI relay and then the fuel pump.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 13, 2012 | 2003 Toyota Corolla
EFI fuse keeps blowing in 1998 Camry
There is only ONE reson why a fuse blows: Something is overloading the circuit and drawing more amperage than the fuse is designed to handle. This is what is known as an "overload" or a "short circuit".
Plesase read the following two articles:
Where's the fuse?
What else could be wrong?
If after reading these two articles, you think you would like to try your hand at tracking this down and fixing it yourself, and you are sure you have the correct equipment (as listed in the articles), let me know and I will help walk you through it.
Apr 18, 2012 | 1998 Toyota Camry
Engine wont start,efi 15amp fuse keeps blowing
EFI (electronic fuel injection) is a nasty fuse to blow. Unplug EFI module for 5 minutes. Plug it back in and try to start it immediately to confirm a heating short or possible bad module.
Apr 23, 2011 | 1994 Toyota Pickup
Keeps blowing 15a efi fuse 1991 toyota pickup 2.2 re
Dec 12, 2008 | 2004 Toyota Corolla
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
