Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Whirlpool cabrio dryer is running, all ducts and traps are clean but no exhaust coming out of vent.
    Sergeant:
  • 239 Answers
Is the fan running. Is it direct drive or belt driven.
If it's not running, you may have to replace the motor or the fan belt.
Posted on Feb 16, 2014
  • Strnj1
    Strnj1 Feb 16, 2014
    Obviously the first two sentences should have ended in question marks.
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
  • 12 Answers
SOURCE: dryer does not heat
Check the thermal cut-off, the thermostat, and the heating element. Most times one of the tree is the culprit.
I have seen a bad timer cause the no heat problem a few times but 99% of the time it is one of the three I mentioned.
If you change the thermal cut-off make sure you get both the cut-off and the thermostat. A stuck T-stat will take out a cut-off in a big hurry.
Posted on Feb 27, 2009
SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
Posted on Jun 10, 2009
  • 767 Answers
SOURCE: Whirlpool Cabrio dryer problem
Hello my name is Heath the problem is the heating element is probably burned out and will need replace.
Posted on Apr 08, 2010
heatman101
  • 43501 Answers
SOURCE: whirlpool cabrio dryer not drying. Sounds like
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 10, 2010
Sensor and computer have been replaced on cabrio dryer yet check vent light still comes on
Did you clean the exhaust duct from end to end?
Some of these have a two-belt system where the second belt turns a fan blade that resides in a plastic housing beneath the drum... the pulley will come loose and fall off sometimes which can cause this error... Help Me Find My Model Number RepairClinic com
Oct 07, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
What could cause dead animal odor from my whirlpool cabrio dryer?
check in the dryer's exhaust hose right behind it, there could be a dead animal in it. I had a squirrel in it once. true story :S
Sep 02, 2015 | Whirlpool Dryers
Electric dryer duct fire
I think this question must have been misclassified, as it states that this is regarding a Problem with Whirlpool Cabrio WTW6600SBT Top Load Washer. I will assume this is about your dryer. Dryer fires are not as uncommon as most would believe. It sounds like you were utilizing the nylon or plastic dryer vent hose. The lint in your dryer that accumulates can catch fire after years of use. A good dryer vent cleaning will cover your vent duct from the wall to the vent exit outside the home. You should have this cleaned by a professional and have an internal dryer cleaning conducted. If funds are tight, you can do this yourself by pulling the dryer out and running the vacuum cleaner extension into the dryer vent opening after you remove the melted hose. Just be careful when pushing the hose extension up the exhaust as some models will have a heating element in line. If you feel any resistance, that is when you stop pushing the hose in and just suck any lint you can from that point. This is a good start, but a good full internal cleaning of your dryer is warranted. Make sure you unplug the dryer before attempting any cleaning or servicing. Safety first!
Feb 19, 2014 | Dryers
Whirlpool cabrio 7.0 cu. ft. Capacity electric dryer will start, turn, and heat. It just won't dry the clothes because no exhaust out of line. The lint trap and the hose has been cleaned.
you have to clean out the dryer too,that's a gas dryer it should be taken apart and cleaned out at least once a year so you don't have a fire.you have to unplug the dryer,pull it apart and clean out the cabinet where the motor is and the gas tube,then clean out the blower wheel and the duct that the lint filter slides into,if the vent line is long stick a leaf blower into the line and blow it out.if you live in ma. and need someone to check it out peter de's appliance is a good service to call 781-438-9442
Feb 16, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No air at vent
Sound like you need to replace the heating element.
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Jan 01, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
No flow coming from exhaust vent at back lower bottom of unit, lint screen is clear.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 02, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio dryer not drying. Sounds like its running but no air coming from exhaust.
heatman101
Sep 08, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Clogged lint inside dryer exhaust
there is a vent cleaning kit that can be baught at lowes or home depot and comes with attachments to get down inside the lint trap to be vaccumed out.
you can also lift the lid and remove the front panel and get to the trap area
Mar 28, 2010 | Whirlpool LER4634J Electric Dryer
A sock fell in the vent of my whirlpool dryer
If you mean the lint trap, try this: Unplug the dryer. With a dryer brush (~$10.00 @ Lowe's/similar), bend to approximate the curvature of your cavity and try to retrieve. If this doesn't work, slide/scoot the dryer out and remove the venting duct. Carry outside and dump. If no sock there, look into the dryer exhaust (where the duct connects). Use the brush again to retrieve said sock (and generally clean as you go, as it never hurts). Also look at your vent where your dryer exhaust passes through the wall, clean as you go..... This should get you back up and running.
Regards, --W/D--
Jul 17, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
112 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
