Question about Keurig Vue V500 Coffee Brewer
Pump makes a funny sound
Doesn't fill the proper amount of coffee
  • 3 Answers
SOURCE: It is only making a little bit coffee at a time
Keurig rep told me they recently redesigned pumps. I think this is a problem with new design. I would return.
Posted on Feb 08, 2010
  • 5 Answers
SOURCE: Our Keurig coffee maker does not work properly.
It sounds like your menu button (Black) is being hit first. Is the button stuck down or has anything been spilled on the control area. The buttons may be shorting out and being triggered inadvertently.
Posted on Feb 10, 2010
heatman101
  • 43501 Answers
SOURCE: When I press for a large cup, it doesn't seem
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: coffee brews but doesn't fill cup, already
heatman101
mc1bean
  • 3053 Answers
SOURCE: I purchased my Keurig Platinum coffee pot last
Hello, this is common. The pumps on these machines are not real good pressure. Sometimes you have to help it prime for the pump to work.
So one very good way to solve the problem is to turn the machine on and lift the water reservoir up just a couple of inches and then jam it back in place fast and hard. With this way is like it injects just enough pressure into the system to open the check valve and when the motor pump will run you will realize that immediately water will passing through from reservoir to brewer tank. This procedure has to be done often between cups.
From what we seen in internet their hundreds about the same problem but we have not see any serious response about it From Keurings customer service yet.
One other important and related problem frequently reported is the irregulars doses of coffee like HALF-FILLED CUPS of coffee e.t.a
This must be redesign from Keuring factory since there is not much we can do about it to solve once for all even if they will replace your machine with a new one you will have the same problem in few weeks. And definitely this not a problem due your Electricity in your area or due to hard water. However hard water areas will face bigger and more intensive the above problem so one more suggestion is to decaling the machine every week this will help a lot.
If you find the above helpful please remember to vote for it
Posted on Oct 13, 2011
When I press for a large cup, it doesn't seem to fill in with as much coffee as before. I only seem to get a small amount each time.
heatman101
Jun 15, 2011 | Keurig Special Edition B60 Coffee Maker
I just descaled my coffee maker and now it doesn't make a whole cup, it says ready to brew, push the button and nothing happens, it shuts it's self off which it never did before. It makes a sound like it...
After the pump fills the keurig and a sensor detects the proper fill level, a valve closes and a 12Volt air pump turns on and pushed the water out of the internal resevoir to the head of the unit.
My B70 air pump siezed up.. (actually formed rust in the friction bearing). I had to take the back off and the pump is located behind the water resevoir. had to remove the pump and test it with a 12Volt power supply.. it didnt spin... so I disassembled the air pump and found the shaft stuck with rust .
Used "Kroil" or you can also use WD-40 on the shaft to free it up... re assemble the pump and re-solder the wires back tp the pump...
worked for me.
good luck.
Apr 17, 2011 | Keurig Platinum B70 Coffee Maker
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
My keurig won't make it's proper cup amount. It only will fill a 1/4 of the way. Can you tell me what might be wrong
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Jan 02, 2011 | Keurig Elite B40 Coffee Maker
Keurig Vue V500 Coffee Brewer Logo
99 people viewed this question
Top Keurig Home Experts
Donni Steen
Tom Chichester
Are you a Keurig Home Expert? Answer questions, earn points and help others
